symptoms of a bad IAC ?
Old 04-11-2005, 09:57 AM
R6E6I6D's Avatar
Default symptoms of a bad IAC ?
i have a horrilbe idle problem the thing revs and drops revs and drops and i was just wondering if anyone else has experienced this problem, i have also just sprayed down the entire intake with 3M throttle body/carb cleaner and it just started after this... help me out if u got/had/heard of the problem
Old 04-11-2005, 10:13 AM
IVI
IVI's Avatar
Default Re: symptoms of a bad IAC ? (R6E6I6D)
edit: check ur vaccum hoses.
Modified by IVI at 2:53 PM 4/11/2005
Old 04-11-2005, 10:37 AM
XSIWANNAB's Avatar
Default Re: symptoms of a bad IAC ? (IVI)
nope its your IAC,you need to change it,and if you do might aswell change your throttle cable.only reason is becuse it just happen to me in my golf.and its good to change the cable anywys, cuz im preety sure u drive hard so its probably stretched.
Old 04-11-2005, 05:58 PM
R6E6I6D's Avatar
Default Re: symptoms of a bad IAC ? (XSIWANNAB)
i dont think ill need to replace it aslong as i clean the crap out of it and let it dry and for the throttle cable its adjustable sooo i can just tighten the screw a bit i just got the specs off alldata today soo illl look into that thanks alot
shabam
12-09-2007 07:52 PM
shabam
10-09-2007 05:10 PM
shabam
10-09-2007 02:20 PM
si0385.
02-03-2006 08:19 PM
Hcivic88
13
11-04-2002 03:36 PM
Quick Reply: symptoms of a bad IAC ?
