Strange problem. RPMS bounce and the car dies - Honda-Tech
Old 02-16-2011, 02:09 PM   #1
Default Strange problem. RPMS bounce and the car dies
I've got a 96 Integra LS, with what I think is an electrical problem but I'm not sure. One of my friends tells me its either a bad ground or the dizzy, another is telling me it could be the ECU.
Symptoms:
  • Car starts fine and idles perfect for about 30 seconds.
  • Tach needle twitches first then bounces violently with no effect on the motor for about a minute.
  • Then the car begins to sputter occasionally
  • RPM's fall to zero and the car dies.
What I have replaced/fixed:
  • Cleaned IACV
  • Replaced Fuel Filter
  • Replaced Ignition Coil
  • Battery & terminals are fine
  • Wires and plugs have been replaced in the last 10K
  • No CELs
It used to only do this while driving, the rpms would bounce a little with no effect on the motor but every once in awhile it would cause the car to jerk. And this problem would come and go, happen one day and not the next with no change in the temperature outside.
BladesTeg is offline   Reply With Quote
Old 02-16-2011, 04:03 PM   #2
Default Re: Strange problem. RPMS bounce and the car dies
How high are the RPM's jumping up to? Is it revving up and down while this is happening?
pack92 is offline   Reply With Quote
Old 02-16-2011, 05:11 PM   #3
Quote:
The jumping gets progressively worse. Starts off jumping 200-300 rpms then jumps as much as 4000. The car does not rev at all, it sounds like its just idling normally. But after about a minute or so of this the RPMS drop to 0 and the car dies.
Old 02-16-2011, 06:28 PM   #4
Hmm dont know what that could be . I was going to say that if the car is idling up and down with the RPM it could be a vacuum leak but what your describing doesnt seem like that. Sorry I could not be of any help.
Old 02-17-2011, 09:59 AM   #5
Any other ideas? I'm going to try and replace the ICM tomorrow, but the screws are stripped.
Old 02-17-2011, 10:24 AM   #6
Function7's Avatar
This really sounds like a bad ignitor module (i.e. ICM). I've had it happen to me on my old car. The tach would jump up/down and the car stumbles off and on. Eventually it'll give out and the engine will stall and you won't be able to restart it.
Function7 is offline   Reply With Quote
Old 03-02-2011, 08:34 PM   #7
Problem fixed. It was the ICM plus a stripped wire. One of the wires was arcing to the ICM and fried the ICM.
Old 03-03-2011, 10:01 AM   #8
::ek-4::'s Avatar
I have the same problem, so glad there was another thread up to help me with my Teg. Thanks HT
::ek-4:: is offline   Reply With Quote
2000 honda civic ex rack and pinion replace rpms bouncing??? Help!!! MTracing Tech / Misc 12 12-26-2011 10:50 PM
Bouncing Idle Problem (IACV or FITV?) JLUDE01 Honda Accord (1990 - 2002) 16 01-13-2010 12:27 PM
few problems, need help asap. ls19integra95 Acura Integra 5 03-19-2008 02:21 PM
Tach bounces above 7000 rpms, drops out of vtec sometimes JasonST Honda Prelude 13 08-24-2006 06:08 PM
tachometer bouncing around Apd3111 Honda Accord (1990 - 2002) 5 01-09-2005 06:34 PM
Tags
car, dies, distributor, down, driving, drops, dying, honda, jumping, jumps, myaccord, needle, problem, rpm, rpms, stalls, subaru
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
