need help with hoses on skunk2 manifold
im going from jg manifold to skunk2 so im missing some hoses and having trouble figuring out where some go! heres some pics
its hard to see in the pic because its under the fat hose. so i drew a little pic of what it looks like on the side view
Re: need help with hoses on skunk2 manifold
First Pic, Hose goes from the TB to the Little black box that you have an open hose thing on Pic 2.
Pic 3 Not sure what that is, Its not your map what is it?
Pic 4 you have to plug that hole, Its not used.
Pic 5 Either plug it or it runs to something on the firewall.
this is the way my mechanic did it
the inner hose went to breather box and intake manifold, he use a "T" to split the lines
i got one last question for pic 4 with that tiny hose that has coolant running through it. what did you guys use to plug it? i thought a little rubber plug woulda worked but it shot out lol right now i have a hose connected to it with clamps and plugged the other end of the hose with a screw and clamps
For pic 4, I used a small vacuum line with a screw but no clamp. You should be fine.
This might help for the other stuff:
http://www.performanceforum.com/wesv...k2/skunk2.html
