Strange humming/grinding sound from front driver's side while turning - Honda-Tech
Old 02-18-2010, 02:59 PM   #1
basmasta7's Avatar
Default Strange humming/grinding sound from front driver's side while turning
Hi everyone,
Here's my situation:
While driving, I hear a humming / slight grinding noise from my front driver's side wheel while turning to the right. The frequency of the noise seems to change once per wheel revolution (indicating that the situation changes as the wheel rotates around). It goes away completely while turning to the left. In other words, when the suspension on that side is loaded, I hear the sound. Also, I don't know if this is related, but the rotor in that corner warps continuously. I swap out new brembos every year or so, and it always comes back. I always use a torque wrench on my lug nuts so that's not the problem either.
My troubleshooting:
I've done quite a bit of searching, and everyone seems to suggest that something like this is a wheel bearing, CV joint/boot, or axle. I had a mechanic replace the wheel bearing and inspect the other items and the noise is still there.
What do you all think?
basmasta7 is offline   Reply With Quote
Old 02-18-2010, 04:32 PM   #2
basmasta7's Avatar
Default Re: Strange humming/grinding sound from front driver's side while turning
Update:
After driving on the highway after the mechanic replaced the wheel bearing, there is now a very noticeable metal to metal rubbing sound when I load the front driver's side suspension (either via a bump or a hard turn). It sounds like it's just the dust shield hitting the rotor or something, but regardless - it seems like there's some movement going on that shouldn't be. Why would the dust shield move independently from the rotor (besides the obvious lack of rotation)?
00 Civic - humming noise that goes away when turning left (new wheel bearings) 93civicsedan Honda Civic / Del Sol (1992 - 2000) 20 05-08-2016 07:19 AM
93 ej2. weird humming noise. suspension problem?? EcivicG Honda Civic / Del Sol (1992 - 2000) 19 03-14-2009 11:28 AM
Stumped...Humming noise from front end. tunes12 Suspension & Brakes 6 04-20-2007 03:07 PM
Steering problem! I need ideas quickly. PLEASE HELP, URGENT!!! NineTwoSi Honda Civic / Del Sol (1992 - 2000) 7 12-18-2006 06:38 PM
Humming noise while turning slowly from the front driver side zrx168 Acura Integra Type-R 2 12-04-2001 01:13 PM
Tags
acura, corners, drivers, driving, front, grinding, honda, humming, integra, makes, noise, side, sound, turning, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
