ingalls camber kit adjust
Old 01-14-2005, 02:05 PM
TURBODC4TEG's Avatar
Default ingalls camber kit adjust
ok can someone plz tell me how i can adjust my ingalls camber kit for the front, my friend did it but kind quick driver side is still kinda in and the passenger is out
is this hard or what?
Old 01-14-2005, 04:54 PM
Default Re: ingalls camber kit adjust (TURBODC4TEG)
up
Old 01-14-2005, 06:28 PM
IMPATIENT's Avatar
you need to go get an alignment.........when i did mine, i adjusted the camber kit to the middle of the slider, tightened it, installed it, then drove 2 miles down the road to get a 4 wheel alignment( i put washers in the rear behind upper arm mounts, ghetto, but works fine), and they did everything else, camber, toe, etc......
Old 01-15-2005, 12:06 PM
Default Re: ingalls camber kit adjust (IMPATIENT)
ok u got any pics, are your fronts straight up
Old 01-15-2005, 05:27 PM
up
Old 01-16-2005, 02:44 PM
Xsi
Xsi's Avatar
When I set mine I just put them both on the lowest possible setting, this left me with about -0.5 degrees which is fine for me because I wanted some negative camber. You will definately need an alignment though
This may give you some info: http://www.integra.orcon.net.nz/camber
Old 01-17-2005, 02:19 PM
Default Re: (Xsi)
thanks man
Dirty Octopus
28
02-20-2010 05:47 AM
FLACO EM1
11-27-2008 01:39 PM
fafsa
04-06-2005 03:41 PM
itsJDMyo
13
01-07-2005 10:40 AM
albert butterbikini
01-16-2002 02:33 PM
Quick Reply: ingalls camber kit adjust
