Stock b18c throttle bodies, and skunk2 intake manifold...
Old 01-09-2003, 10:31 AM
Banned
G a b e's Avatar
Default Stock b18c throttle bodies, and skunk2 intake manifold...
Alright, I have searched, but was unable to come up with a defineate answer. How big is the stock b18c1 throttle body? Is there a difference between OBD1 and 2? How big is the skunk2 Intake manifold for a b18c1? Basically I am interested in port matching. Someone please inlighten me. Should I use a ported and polished stock TB, or should I purchase a new one? If so what is good?
Old 01-09-2003, 10:49 AM
ChapR
Guest
Posts: n/a
Default Re: Stock b18c throttle bodies, and skunk2 intake manifold... (G a b e)
get a type r one, jdmhondaparts is selling them in their special!
Old 01-09-2003, 12:00 PM
Banned
G a b e's Avatar
Default Re: Stock b18c throttle bodies, and skunk2 intake manifold... (ChapR)
$360 is a deal, but I am on a strict budget. If it is possible, I would like to get my b18c1 TB port patched to my skunk2 Intake Manifold. Can it be done?
Old 01-09-2003, 02:51 PM
ULTRA911's Avatar
i got both throttle bodies. a '94 & 01 one. both same size, 60mm. i notice the '94 one has a fast idle valve on the bottom portion of the throttle body whereas the '01 doesn't. '94 one has a vacumn line near the map, '01 just has a hole where the vacumn line should be at, but isn't present. you could always check ebay for pics so you know what i'm talking about. if i could find a ruler in my place, i could give you a definite answer to the size of the sk2 manifold. i say bore out your current TB, more cheaper than spending $300+ for a new throttle body.
Old 01-09-2003, 07:01 PM
Banned
G a b e's Avatar
Default Re: Stock b18c throttle bodies, and skunk2 intake manifold... (ULTRA911)
Thanks for the info. I found out that the skunk2 IM is 64MM. My next question is can the stock TB be ported to 64MM?
Old 01-09-2003, 10:40 PM
Mr. Softee's Avatar
ive run a gsr tb to a skunk2 manifold. you get a slight whistle. not worth spending 300$ for the few hp gain you will see.
Old 01-10-2003, 08:26 AM
Banned
G a b e's Avatar
Default Re: Stock b18c throttle bodies, and skunk2 intake manifold... (94goldjungsr)
What are you saying? That ths skunk2 is a waste of money, or that port matching a GSR TB to match it is a waste of money?
Old 07-11-2004, 06:22 PM
BLiMP's Avatar
Ohhh so thats what the whistling is. I knew it was from the intake, i was thinking manifold leak or just how the filter was designed. Alright thanks for clearing that up. It is really loud though, whenever someone asks me what it is, I tell them its my cat.
95egianp
03-18-2013 04:46 PM
stutler_jdm
05-14-2011 09:05 PM
aemintgsr
10-26-2009 07:21 AM
jimbrown
12
09-10-2007 08:00 PM
digital sol
06-24-2006 01:52 AM
Quick Reply: Stock b18c throttle bodies, and skunk2 intake manifold...
