Stock 95 LS Engine Replacement Project Lots of Pictures
My father in law killed his B18B1 so we purchased a B18B long block from HMO and dropped her in last weekend.
Pictures of the dead motor removal
Picked up a long block from HMO - Clean and Assemble
Re: Stock 95 LS Engine Replacement Project Lots of Pictures
i believe the VC is painted Honda marine blue. last used on Honda outboard boat motors in like 84 or 85
haha I had my valve cover painted blue like this initially. I liked it. It's not having any ground problems, but I'll swap the ground over a bolt regardless
unless you painted the VC or the OP post the exact color you don't know for sure.
Not saying your wrong just pointing out the facts.
second the three big domestic auto makers all ran a shade of blue and 90% of veteran auto painters can't even tell witch one is witch when there side by side
ford also ran 2 different colors of blue over the years.
and the old honda outboard boat motors had blue painted Power heads (IE the Engine)
and third I doubt the pix were taken with a High end camera that was white balanced to the light source and shooting in Raw format.
so to say it IS ford blue would be the same as saying 91 Teg has a b18c1 just by looking at the gas cap.
this is why I said I believed it was honda marine blue.
i worked at a marina for about 3 years and fixed alot of honda outboard motors
LOL I didn't know the blue would cause such havok with you guys It was sprayed with High Temp Enamel from Pepboys - I don't know if the paint can said Ford Blue, or Marine outboard Honda blue, or just simply "Blue"
blue2000em1
Appearance Build Threads
15
07-29-2008 05:51 AM
