step by step help with removing entire A/C from da ???
can someone give me a step by step on how to remove the A/C from a DA integra. how to start and which thing to do first and last. thanks alot. how long should it take total ?
Re: step by step help with removing entire A/C from da ??? (DA-Steve)
can't, im going turbo and theres no way around it. ive seen the lengths people have to go to keep the a/c in a DA and its almost tooooo much work if its even possibe.
Guest
Posts: n/a
Re: step by step help with removing entire A/C from da ??? (redDAinteg)
i took it out of my DC in about twenty - thirty minutes. I started with the compressor I just un did the hose... let all the ac juice (can't remember what its called for some reason) out. don't breathe that **** in. and once it was done pulled off the copmressor and just started undoing all the brackets for the hoses. and I just un bolted all the hoses at each connection and they pulled right out. that way you can either put it back in or sell it or whatever.
Re: step by step help with removing entire A/C from da ??? (so.dark.the.con.of.man)
how do you let all the refrigerant out ?? and you have to remove the radiator to get the condenser out right ?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg »</TD></TR><TR><TD CLASS="quote">how do you let all the refrigerant out ?? and you have to remove the radiator to get the condenser out right ?</TD></TR></TABLE>
I just broke the bolt on the compressor loose and pulled the hose up. just wear saftey glasses and look away and get away from the car don't breathe it in. and I just undid the top brackets on the radiator and leaned it forward and slid it out. (the condensor that is)
Jose-aka-Pedro
05-14-2007 09:46 AM
