starting problem really need help
hey guys i have a 1995 acura integra with 1.8 dohc none v-tech.
And ive been trying to figure this out for a year now but no luck.
So the car starts up fine when engine is cool once it gets to normal runing tempeture if i turn it of and try to turn it on it will not start it will just crank over and over untill engine cools off and then it will start. i have fuel presure and spark even when the problem is there and i have changed the main relay. and the tps. But no luck can anyone help ?
Re: starting problem really need help
well 9 out of 10 time a no restart when hot is the ICM in the disstributor but you say you have spark so that leave fuel but you say you have pressure so i would say your not getting injector pulse.
this could still be the dissy as the sensor that tells the ECU when to pulse for fuel is in there but it could also be the injector drivers in the ECU.
wahahn
12
12-29-2008 12:33 PM
EG TYPE-R
11
08-04-2004 04:56 PM
