srs light
Old 09-01-2003, 07:44 PM
integra pride's Avatar
Default srs light
my srs light never goes on not even b4 the car start
i was told there are airbags
is it even if there are no airbags the srs light will be on all the time
need help on that
Old 09-01-2003, 08:05 PM
PatrickGSR94's Avatar
Default Re: srs light (sauado)
the bulb is probably burned out, as it should be on if there is a problem. Go ahead and replace it so that you will be able to see it if there ever is a problem and it does come on. My dad survived a near-head-on crash at 60+ mph w/ no injuries at all back in June, and I attribute that 100% to the seat belts and airbags, so you always want to make sure they are functional.
Old 09-01-2003, 09:32 PM
how do i replace the bulb and is it located in the back of the cluster
thx
Old 09-11-2003, 06:55 PM
DumpedSi's Avatar
Default Re: srs light (usdm integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm integra &raquo;</TD></TR><TR><TD CLASS="quote">how do i replace the bulb and is it located in the back of the cluster
thx</TD></TR></TABLE>
no, the bulb is located in the engine right next to the tranny...j/k, chances are the seller who sold you the car pulled the bulb because the SRS light was on. All you have to do is remove the cluster, flip the SOB over and look to see which one is the srs light plugs into, I'd just try a bulb next to it to see if thats the problem
Bleakened
12-12-2014 12:29 PM
eaz_e
08-19-2008 04:00 PM
Slava.
10
04-29-2006 07:33 PM
KayOs
08-15-2003 03:35 PM
CaRiXma
04-13-2003 09:51 AM
Quick Reply: srs light
