srs light
Old 07-31-2006, 12:09 PM
azn_mien's Avatar
Default srs light
my trip meter isn't working, can that cause my srs light to be on?? i try resetting the srs light a few times but something is still causing the srs light to be on...
car: 96 integra ls
Old 07-31-2006, 12:19 PM
Lan
Lan's Avatar
Default Re: srs light (azn_mien)
Loose wire? Deployed airbag? Your odometer isn't working? Maybe loose wires or a bad cluster? Try the fuses too
Old 07-31-2006, 12:24 PM
jdm_bones's Avatar
Default Re: srs light (Lan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">Loose wire? Deployed airbag? Your odometer isn't working? Maybe loose wires or a bad cluster? Try the fuses too </TD></TR></TABLE>
^ yup, also have installed an aftermarket steering wheel without SRS/ airbag...
Old 07-31-2006, 01:55 PM
VtecAdvantage's Avatar
well.. the srs light shouldn't be causing it (my srs light has been on for 3k miles)
Old 07-31-2006, 03:20 PM
HaTa's Avatar
How do you get the light to stay off ? I just put a non srs wheel in mine and the lights kind of annoying.
Old 07-31-2006, 03:41 PM
azn_mien's Avatar
everything on my Cluster seems to work, except the Trip Meter.....(odometer works, etc...)
stock steering wheel....
fuse looks ok.... i don't know which wires should i check to see its loose or not....
jhaag115
08-08-2009 12:41 AM
scarsofterroreg
13
02-01-2008 06:28 PM
bb4ninja
02-21-2007 08:25 AM
Slava.
10
04-29-2006 07:33 PM
delux247
Honda S2000
02-22-2004 11:20 PM
Quick Reply: srs light
