spilled brake fluid...help
Old 10-02-2007, 02:55 PM
matryx's Avatar
Default spilled brake fluid...help
After reading the article on how to bleed/flush your clutch fluid I went out to get clear tubing and some DOT3 brake fluid.
While I was trying to open the bleeder I accidentally spilled some brake fluid onto the engine and headers and some other parts.
Is this going to cause any damage to my engine or any parts that I spilled brake fluid on? I tried cleaning it with a rag and took of the heat shield and tried to wipe it down.
Whats a good way to clean the brake fluid or is it going to be fine like that?
Old 10-02-2007, 02:58 PM
Darth ModerVader
Padawan's Avatar
Default Re: spilled brake fluid...help (matryx)
I'd use brake cleaner and/or a good degreaser to remove the fluid as soon as possible.
Old 10-02-2007, 03:07 PM
Mad_Hatter_Sleeper's Avatar
Not on paint
Both brake cleaner and brake
fluid eat paint
Old 10-02-2007, 03:11 PM
posHonda's Avatar
It shouldnt be too big of a deal if you just got it around the block and header. If you got it on your paint you better clean it asap.
Old 10-02-2007, 03:45 PM
matryx's Avatar
Default Re: (iVteC_PoWeR)
I don't got it on the paint. Just got it on the stock headers and whatevers underneath and some around the block. Doesn't look like I got it on any belts either.
Old 10-02-2007, 04:29 PM
Daisy... Daisy...
Dogginator's Avatar
Default Re: (matryx)
Rinse with water.
Old 10-02-2007, 05:10 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Rinse with water.</TD></TR></TABLE>
lol but brake fluid is oil based.
Just get some engine degreaser. I use black magic...because it cleans as it shines. I sound like a commercial.
Available only at your local autozone lol.
Old 10-02-2007, 06:05 PM
Daisy... Daisy...
Dogginator's Avatar
Default Re: (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
lol but brake fluid is oil based.</TD></TR></TABLE>
http://en.wikipedia.org/wiki/DOT_3
Are you seeking a chemistry lesson? Brake fluid is quite hygroscopic. Water will rinse it away without risking the paint.
Old 10-02-2007, 06:14 PM
KaBlookie's Avatar
Are you seeking a chemistry lesson? Brake fluid is quite hygroscopic. Water will rinse it away without risking the paint.</TD></TR></TABLE>
^ tr00f
that's why people always look for high wet boiling points for brake fluid...it absorbs moisture in the air enough so that its boiling temperature lowers noticeably.
try cleaning it off with some water first and if there's still residue left, then go for engine degreaser.
also check to make sure it didn't get on any non-metal gaskets...it can wear away at them over time
Old 10-02-2007, 08:31 PM
B serious's Avatar
fair enough
Old 10-03-2007, 06:09 PM
matryx's Avatar
thanks. how do I clean the brake fluid on my drive way? can't wash it with water can i ?
Modified by matryx at 2:51 PM 10/5/2007
Old 10-03-2007, 06:11 PM
DOHCgarage919's Avatar
Location: Why To Steal My Car, NC, United States Of America
water will not rid of it all like other indicated , use that junk spray and wash it off cuz brake fuild will take your paint off quick
Old 10-03-2007, 06:14 PM
__oversea's Avatar
long as it didnt get on paint, you are fine. and you can just pray some brake cleaner.
Old 10-05-2007, 01:08 PM
Default Re: spilled brake fluid...help (__stig)
dont get brake cleaner etc on paint it will take some of it off like clear coat or wax, brake cleaner, carb cleaner etc is no good to spray on paint
wezzel19
03-24-2010 05:28 PM
The AW Alchemist
Paint and Body
07-09-2009 09:49 PM
effinnwackk
12-15-2004 02:26 PM
Powered by Honda
02-20-2002 12:40 PM
Quick Reply: spilled brake fluid...help
