Speedo/Tach/Temp/Dash Clock Not Working
When I got in my car this morning none of this was working -
RPM Gauge (Tachometer)
Speedometer
Fuel Gauge
Oil Light
Dash Clock
I checked all the fuses and I couldn't find any blown.. or any even related to these things. The car still hits vtec.. drives normal etc. Just this doesn't work.
Anyone know the problem?
TIA
-Nick
Speedometer
Fuel Gauge
Oil Light
Dash Clock
TIA
-Nick
Re: Speedo/Tach/Temp/Dash Clock Not Working (integlude)
****, then its definately electrical, looks like you need to get a Voltmeter and test all wires to see which one isn't giving off current, (long process) good luck!,
Re: Speedo/Tach/Temp/Dash Clock Not Working (NickGSR95)
Yup check both fuse boxes man. The one in the engine and the one under your steering column to the left. The one under the steering column has alotta small ones so it may be a while unless you have a Helms or something. Last time my cluster/dash lights weren't working. Found a bad fuse in the box under the steering column. Just replaced it and it was all good.
you sure you checked all the fuses? i had the same problem before but i didnt check every fuse, it turned out to be the back up fuse or something like that
andertom
08-03-2008 05:24 PM
Augustin
07-02-2007 04:51 PM
