Speed Sensor wiring diagram? - Honda-Tech
Old 06-10-2010, 05:20 PM   #1
Default Speed Sensor wiring diagram?
Hi guys,
I was trying to replace my transmission. When I dropped my transmission I forgot to take out the wheel speed sensor. The three pins connected to the connectors came out. Right now my speedometer isn't working and I hope that it's the wiring for the speed sensor. Can somebody tell me the order of which the pins need to be in, that would be greatly appeciated!
I think I have them in order from left to right.
blue/white, black/yellow, and black.
Thanks alot!
kuy289 is offline   Reply With Quote
Old 06-10-2010, 05:21 PM   #2
Default Re: Speed Sensor wiring diagram?
Sorry I forgot to mention, it's a 1996 Integra LS.
Old 05-03-2011, 08:49 PM   #3
jdmwojo's Avatar
i need to know the same thing please!
jdmwojo is offline   Reply With Quote
Old 05-03-2011, 09:04 PM   #4
fcm
Old Fart
fcm's Avatar
I will have to look at my 94, [no pinout in my Haynes manual] and it's at my shop so can't do it till the morning. 94
fcm is offline   Reply With Quote
Old 05-03-2011, 09:05 PM   #5
wunfstgsr's Avatar
not that hard to figure out! i know the black is on the right and the wire with blue is first then the other is in between, but just wire it up then plug them in in difrent orders till you get the signal, you can pull the white clip inside of the plug out, use a pin or pointed pin to push the metal tab and wire out the plug housing then just place them around in difrent orders and plug it back in till the signal comes and your done.
wunfstgsr is offline   Reply With Quote
Old 05-03-2011, 09:53 PM   #6
From the Hayne's (factory) electrical troubleshooting manual:
The connector (C112) has three pins...
1) Blk, is ground
2) Blk/Yel, is power from fuse 24 (15A) and hot in ON or START
3) Blu/Wht is vehicle speed to
... ECM, C409, pin 18 (Orn)
... TCM, C419, pin 5 (Orn)
... Cruise Control, C417, pin 12 (Orn)
... Speedo drive ckt in the Gauge Assy, C560, pin 6 (Orn)
... Maintenance reminder ckt, C568, pin 3 (Orn)
That help?
This for the 1996 edition Integras.
Mark
mark@silbernage is offline   Reply With Quote
Old 05-12-2011, 12:59 PM   #7
Chrisfrom1986's Avatar
1) Blk, is ground
That help?
Mark
Yes it does thanks.
Chrisfrom1986 is offline   Reply With Quote
obd0-obd1 oxygen sensor question got_no_sol Honda CRX / EF Civic (1988 - 1991) 1 09-26-2016 09:26 AM
VSS wiring question. Pin A18 13173 Engine Management and Tuning 2 01-18-2014 08:37 AM
Help, AT problem, throwing Code 15 and Code 4 Mishako129 Honda Accord (1990 - 2002) 9 03-17-2013 12:29 PM
how do i remove the speed sensor? 98bucket Acura Integra 13 09-10-2010 09:51 AM
Speed sensor 94 ronqqq Honda Accord (1990 - 2002) 1 09-12-2006 05:47 PM
Tags
2001, 92, 98, del, diagram, honda, integra, nintegra, senor, sensor, sol, speed, speedsensor, type, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
