Slight oil leak form valve cover......
Old 10-22-2008, 09:33 AM
smittysbmx@aol.com's Avatar
Default Slight oil leak form valve cover......
I have a 1996 acura integra, i jus traded it for my old 1993 honda del sol. The integra is an ls and has a slight leak from the front left corner of the valve cover? Thinking maybe just the a valve cover gasket, which i will replace soon anyways since I am painting the valve cover. Any other idea on what it could be besides that?
Old 10-22-2008, 09:46 AM
weavertime1's Avatar
Default Re: Slight oil leak form valve cover...... (smittysbmx@aol.com)
Camshaft seal...very very very common issue in DOHC honda engines. Inexpensive part, but you do have the remove the exhaust cam in order to change it. A note...when installing a valve cover gasket, it is important to only use silicone in the cam cap corners (8 small spots). Good luck!
Old 10-22-2008, 12:05 PM
eight equals equals equals D
Tim2179's Avatar
Default Re: Slight oil leak form valve cover...... (weavertime1)
Not the camshaft seal - that would be on the right side, just before the cam gear. The left side is where the all too common leaky cam CAP seal is. You don't have to take the cam out, but you will have to take off the valve cover and loosen the cam cap on the exhaust side. Get a new metal cam cap seal with the dual rubber seals.
Old 10-22-2008, 01:17 PM
Default Re: Slight oil leak form valve cover...... (Tim2179)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tim2179 &raquo;</TD></TR><TR><TD CLASS="quote">Not the camshaft seal - that would be on the right side, just before the cam gear. The left side is where the all too common leaky cam CAP seal is. You don't have to take the cam out, but you will have to take off the valve cover and loosen the cam cap on the exhaust side. Get a new metal cam cap seal with the dual rubber seals.</TD></TR></TABLE>
Sorry I mispoke about the cam cap seal. That seal is what I meant...everyone just calls it the cam seal.
Old 10-23-2008, 09:34 AM
Thank you for your help, i will try that and see what happens. i will get back to you as soon as i get a chance to tell if that was what was wrong.
Thank you!
Old 10-30-2008, 09:15 AM
Where might be the best place to get this part? Any recomended brand?
Old 10-30-2008, 09:30 AM
From what I have seen many are the same...the aluminum ones I have seen all seem to pretty much be the same. Here is what a search on Ebay brought up...
Check the next thread by AWD terror! sorry dude!
Modified by weavertime1 at 10:54 AM 10/30/2008
Old 10-30-2008, 09:51 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weavertime1 &raquo;</TD></TR><TR><TD CLASS="quote">From what I have seen many are the same...the aluminum ones I have seen all seem to pretty much be the same. Here is what a search on Ebay brought up...
http://shop.ebay.com/items/_nk...cat=0</TD></TR></TABLE>
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebay &raquo;</TD></TR><TR><TD CLASS="quote">0 results found for nkw= honda cam seal& sacat=0& fromfsb=& trksid=m27</TD></TR></TABLE>
Fixed it for ya:
http://shop.ebay.com/items/?_n...cat=0
BigC-ivic
08-03-2005 08:47 PM
vtec69
01-10-2003 05:31 PM
04accordV6
06-14-2002 10:27 PM
SIK IN DA HED
08-03-2001 07:35 PM
Quick Reply: Slight oil leak form valve cover......
