Skunk2 ultra and 74mm tb help on 97 gsr
ok so I bought a gsr and the guy threw in an ultra Im and 74 mm tb so I ripped the stock stuff out and then realized the throttlebody has no coolant fittings on it or anywhere to put some. How can I re route the lines for my iacv and also I have the iacv relocate kit but I'm not sure how to install it. Need to get my car running again if anyone has done this same setup please help
Re: Skunk2 ultra and 74mm tb help on 97 gsr
Well on my b16a2 I just removed all the coolant hoses that went to the throttle body/IACV and ran two fresh lines from the port on the coolant pipe & port on the coolant housing on the block (I realize a gsr is a bit different) to the appropriate ports on the IACV. As for the IACV relocation kit that comes with the intake, just type "skunk2 ultra street iacv" into google the first five pictures on the google should be more than enough to go off of. When I installed mine I was fortunate enough to have a buddies to reference off of, since he went through the the trouble to figure it out and at the time there wasn't really any info online or from skunk2.
CALC!_JUST_du_IT!
08-14-2007 10:45 AM
