steering rack question
ok so some genius decided to cut all the lines on my rack really really short and there is almost no way to loop the system now what would happen if i just welded the ends of the fittings to plug the holes so nothing came out would this work? also i have no idea how to get fluid in the rack now it seems to be lubed up a little would it hurt anything if i capped the lines off thanks
Re: steering rack question
You can search power steering delete. Their are some good write ups. It would cost around 20-50 bucks depending on what all you get but it will delete your p/s line.
Just caping them is a bad idea because the pressure has to be releaved
Battle Monkey
08-05-2016 03:14 AM
'06-V6-MT
06-30-2015 05:47 PM
