Signs of bent valves?? - Honda-Tech
Old 11-03-2003, 05:50 PM   #1
tuan...'s Avatar
Default Signs of bent valves??
can u guys tell me what kind of signs i should look for if i bent my valves?? i think i bent a bunch of them after shifting into 2nd instead of 4th at 95mph..
tuan... is offline   Reply With Quote
Old 11-03-2003, 06:00 PM   #2
Smoochy's Avatar
Default Re: Signs of bent valves?? (h22poweredgsr)
Quote:
i can't really help but thats some high *** ****
Smoochy is offline   Reply With Quote
Old 11-03-2003, 06:08 PM   #3
[ iLL ] iNt3GrA's Avatar
what did it rev up 2? at that speed must of went up real high
[ iLL ] iNt3GrA is offline   Reply With Quote
Old 11-03-2003, 06:29 PM   #4
tuan...'s Avatar
i have no idea, i dont really remember, it was so quick and i was shocked that i had grinded and didnt noe wat happened. im sure i was in pretty high rpms
Old 11-03-2003, 06:37 PM   #5
Try taking off the intake tube and listening for pssst sounds. I know that on v8s you can hear bent valves through the carb. Or you can rip off the head.
FURACERMAN is offline   Reply With Quote
Old 11-03-2003, 06:43 PM   #6
tilt's Avatar
rough idle. bad compression.
tilt is offline   Reply With Quote
Old 11-03-2003, 06:57 PM   #7
216.226.142.95:27016's Avatar
Default Re: (FURACERMAN)
do a compression test
216.226.142.95:27016 is offline   Reply With Quote
Old 11-03-2003, 06:58 PM   #8
tuan...'s Avatar
yes i hear hissing sounds, also i had a compression test and it was 70, 170, 125, and 95 from left to right and idle is bad. i guess i bent sum valves.. what else might of happen due to overreving?? coulpe of messed up pistons?? any idea how much this is gonna run me?
Old 11-03-2003, 07:18 PM   #9
Komsomol's Avatar
Hmm okay
But a few of us have done this. I actually feel that its a design problem.
Honda could easily have installed a lock out like they have in first gear.
Anyway.. Symptoms would be running on like two cylanders, car stalling,
smoking, generally running like ashit.
Komsomol is offline   Reply With Quote
Old 11-03-2003, 07:21 PM   #10
Mr. Softee's Avatar
Default Re: Signs of bent valves?? (8400RPMS)
replace those valves before one of them breaks and creates a nasty mess. if they are bent enough there will be stress fractures which will not like high rpms, detonation or high cylinder pressures at all.
ive bent 16 ferrea valves before so i fel your pain. shifting at 9500 into 2nd gear from 3rd gear does wonders. my car died and when i took the head off some of the valves were snapped in half.
Mr. Softee is offline   Reply With Quote
Old 11-03-2003, 07:38 PM   #11
tuan...'s Avatar
when it died, could u star tit up again and have a good idle?? my idle is all funny and if i rev it and let off, it dies. right after this happened, my car wouldnt idle at all, then i clean up a couple spark plugs and it starts up hard but would idle. im not driving it right now til i get the head pull and see whats wrong. did u break anything else besides the valveS? any tips on pulling the head? i wanna do it myself w/ a couple of friends. dont wanna pay sumbody to do it, already tight on money.
Old 11-03-2003, 07:40 PM   #12
canuckr's Avatar
Default Re: (h22poweredgsr)
Do a leak down test also if you can. So far I would bet you bent some valves by looking at your compression numbers and what mentioned earlier. If your lucky you just have bent valves, if your not your pistons will be damaged also. Dont feel to bad I did the same thing last week, I wasnt so lucky. Bent all of the exhaust valves and damaged all 4 pistons. At least I have something to do this winter
canuckr is offline   Reply With Quote
Old 11-03-2003, 07:43 PM   #13
B00ST2nR's Avatar
Yeap. Looks like you bent some. That sucks.
B00ST2nR is offline   Reply With Quote
Old 11-03-2003, 08:28 PM   #14
patdemps's Avatar
Default Re: (Skunk2nR)
Bent valves (ticking noise from engine, occassional stall, rough idle...all symptoms.)
Go to c-speedracing.com for any instructions you need on the removal of the head, adjustment of the valves or pretty much anything else needed.
patdemps is offline   Reply With Quote
Old 11-03-2003, 08:41 PM   #15
SubieDude's Avatar
If you want to get specific whether or not its intake or exhaust valve are bent...when you do the compression test put your hand over the throttle body if you feel air coming out its an intake valve same goes for the exhuast out the tail pipe....good luck and lets hope its not coming from both sides
SubieDude is offline   Reply With Quote
Old 11-03-2003, 10:08 PM   #16
Mr. Softee's Avatar
no, i couldnt start it up, i had broken valves in my head. my pistons has some scratches that i dremeled smooth. thats it.
sam
Old 11-04-2003, 06:16 AM   #17
tuan...'s Avatar
yea, air is coming out both ways, feels like im misfiring. an di hear i hissing noise from the intake manifold..
Old 11-04-2003, 06:43 AM   #18
1hotintegra's Avatar
DONT DRIVE IT UNLESS U HAVE TO
1hotintegra is offline   Reply With Quote
Old 11-04-2003, 06:51 PM   #19
tuan...'s Avatar
where on c-speedracing do i go to find the removal of the head??its not in the "how to" section..
Old 11-04-2003, 07:00 PM   #20
Mr. Softee's Avatar
i will tell you how to rmove the head:
set motor at tdc (not required)
take intake off
take exhaust manifold off
take off all sensors from head, intakake manifold, distibutor
take off all coolant hoses
take off valve cover
take off cam caps or whatever is on them based on your head
take out cams
take timing belt off cams.
undo head studs in right order. use a LONG bar. (find a diagram somewhere)
take head off
takes no more than 90 minutes with two people who want to get it done
Old 11-04-2003, 07:20 PM   #21
tuan...'s Avatar
jeez, sounds good. what a tq specs on an h22?
Old 11-04-2003, 08:34 PM   #22
Mr. Softee's Avatar
get a manual
Old 11-04-2003, 08:48 PM   #23
patdemps's Avatar
Default Re: (94goldjungsr)
take intake off
take out cams
take head off
great information
definately hook yourself up with a manuel. you'll need it down the road aswell.
Old 11-05-2003, 05:15 PM   #24
tuan...'s Avatar
how much is labor on install a valvetrain nowadays? or should i do it myself?
Old 11-05-2003, 07:59 PM   #25
Mr. Softee's Avatar
take the head off first. its a pain to do but worth the savings in $
sam
Valve is burnt or bent. Should I put new or take it to machine shop? Jaydeep Honda Civic / Del Sol (1992 - 2000) 5 12-14-2011 01:39 PM
2005 TSX K24A2 Shortblock 25K Crank Northern California (Sales) 2 06-08-2007 08:31 AM
bent valves....? boostnubII All Motor / Naturally Aspirated 1 11-18-2006 11:02 AM
Bent valves~! B00ST2nR Tech / Misc 10 08-18-2002 12:37 AM
How can I know if my valve(s) is bent? 8400 rpm Acura Integra Type-R 12 07-28-2002 09:57 AM
Tags
bent, bmw, e36, h22, hear, integra, m3, repair, signs, stalling, symptom, symptoms, symtoms, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
