Shudder on acceleration
Old 03-24-2009, 02:42 PM
BoltonGSR's Avatar
Default Shudder on acceleration
I started noticing my car shudders sometimes as I accelerate.
I recently had the tires rotated and I dont think they were rotated in the same direction as before. After that is when I started noticing it...
Old 03-24-2009, 02:48 PM
2ndgentegracer's Avatar
Default Re: Shudder on acceleration
When was the last time you replaced your axles. My brother had a vibration and it was the inner cv going out on the driver side. I would check there first.
Old 03-24-2009, 02:57 PM
BoltonGSR's Avatar
I just replaced my passenger axle
Old 03-24-2009, 04:56 PM
dc2teg06's Avatar
Replace both axles. I had the same problem, replaced just the passenger side at first. The problem was still there. After I installed the drivers side that problem was solved.
Old 03-24-2009, 06:07 PM
MumBleZ_94gsR's Avatar
tie rod maybe
Old 03-24-2009, 06:24 PM
teg_95's Avatar
motor mounts. mine did it and i put new torque mounts in. cleared the problem right up.
Old 03-29-2009, 11:19 AM
BoltonGSR's Avatar
Im still having the shuddering. I dont think its any of the above problems listed. I know my passenger side lower ball joint was blown recently. I wander if that could cause it. It only does it when i am at least 50 percent throttle...
Old 03-29-2009, 11:49 AM
fsg231's Avatar
sounds like something is loose, or need all wheels blanced
Old 03-30-2009, 08:56 AM
HeikDiesel's Avatar
Does the steering wheel shake or the whole car itself?
Old 03-30-2009, 02:50 PM
BoltonGSR's Avatar
Feels like the whole car shakes...
Old 03-30-2009, 02:55 PM
HeikDiesel's Avatar
Does the engine cause the shake? Or does something in the suspension make it do that?
Old 03-30-2009, 07:29 PM
DC_Legacy's Avatar
Are you using a light weight flywheel? When my car was stock (LS), I couldnt recall this happening. However since I rebuilt the motor as an LS/V I've swapped to an ITR tranny with an 8lb flywheel.
The car shutters sometimes if I'm making a slight turn as Im pulling out of my driveway in 1st until the car gets rolling. Of course my new clutch grabs pretty suddenly compared to the original which only adds to the problem, probably.
Old 03-31-2009, 08:38 PM
BoltonGSR's Avatar
I am using a lighter flywheel but I doubt thats it. Ive had it in for years. Im gonna have a look at the underside and do some troubleshooting tomorrrow. Ill post the problem for informative purposes if I find it...
Old 04-02-2009, 07:24 PM
BoltonGSR's Avatar
Ok I think ive found the problem. Code 71. Cylinder 1 misfire...
Thanks for all the help
Old 04-03-2009, 05:57 AM
New User
acin92's Avatar
is ur ride lowered if so that could be the problem!
Old 04-03-2009, 06:15 AM
The G2 Racer's Avatar
I had the same issue.
It was a bad upper ball joint, replaced both and aligned the car.
kodylive
09-30-2012 03:43 PM
honda305
03-09-2010 08:11 PM
negro_1087_delta
02-02-2010 09:57 AM
LookingForVTEC
11-21-2002 07:39 PM
ILOVEGIRLS
08-06-2002 05:22 AM
Quick Reply: Shudder on acceleration
