Short Ram vs. Stock Air Intake for best MPG - Honda-Tech
Old 04-21-2012, 06:16 PM   #1
Default Short Ram vs. Stock Air Intake for best MPG
Been searching for best MPG improvements and some have said that the stock intake will give better MPG compared to most aftermarket, does this seem true?
If so, anyone want to trade my AEM Short Ram for a stock air filer?
J
collkid is offline   Reply With Quote
Old 04-21-2012, 06:20 PM   #2
racebum's Avatar
Default Re: Short Ram vs. Stock Air Intake for best MPG
should be virtually no difference. with a good filter neither one will register any vacuum at WOT. aluminum tube vs plastic tube. same thing more or less.
i did a back to back with an HKS mushroom on a 3" aluminum tube vs a stock tube with a k&n. absolutely near identical 1/4 mile times and vacuum readings
racebum is offline   Reply With Quote
Old 04-21-2012, 06:39 PM   #3
TOO MUCH TORQUE's Avatar
i got 3mpg gain with aem sri. the tube doesnt do anything, its the filter. AEM dryflows have a very good balance for filtering/airflow. k&n and similar ones are not as good imo
TOO MUCH TORQUE is offline   Reply With Quote
Old 04-21-2012, 06:57 PM   #4
bnetkillzone's Avatar
Technically it really depends on the temperature entering the intake. Colder air is more dense and therefore uses more fuel because of that increase of oxygen volume.
Hypermilers are crazy about it: http://ecomodder.com/forum/showthrea...mpg-14440.html
bnetkillzone is offline   Reply With Quote
Old 04-21-2012, 07:07 PM   #5
Wow, ya, thats too intense for me. Just was more looking if anyone had personal experience like "I used to get 28MPG but now I only get 25..."
Old 04-22-2012, 10:43 AM   #6
I might try and get a stock one and see if there is a difference.
Old 04-22-2012, 06:47 PM   #7
never knew air filter would effect mpg.. learning something everything.
DubK97EK is offline   Reply With Quote
Old 04-22-2012, 06:50 PM   #8
4DRTEG210's Avatar
Just get a icebox or ct drop in filter and call it a day... imo
4DRTEG210 is offline   Reply With Quote
Old 04-22-2012, 10:35 PM   #9
racebum's Avatar
Quote:
for the most part they don't...unless they are restrictive,
ALL the good filters. aem dry flow, K&N, hks, greddy etc will not be a restriction on an NA 4 cylinder.
a dirty paper filter really can effect mpg though, same with melted cats
Old 04-22-2012, 10:46 PM   #10
91b18a1ls's Avatar
I personally think if you're worried about gas mileage...keep the car stock. Either one isn't gonna make much if any difference. Making sure you're afr is good will save you more gas than the type of intake
91b18a1ls is offline   Reply With Quote
Old 04-22-2012, 10:56 PM   #11
k&n was way too free flowing in my opinion. stick it up against a light and you'll see what i mean. i had an injen sri(with k&n filter) and i notice my tailpipe had noticeable traces of carbon or soot after a 10 mile drive. that can't be right and it was consuming more gas, so i ditched that and bought an AEM sri and noticed a 3mpg gain over stock intake and my exhaust tip is super clean.
Old 05-22-2012, 09:11 PM   #12
only purpose for an aftermarket intake is to make a car cooler (no pun intended)
god.o.war is offline   Reply With Quote
Old 05-24-2012, 08:53 AM   #13
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
I got a improvement in my f22 accord of about 2-3mpg. My lexus, I am using the stock box with a k&N filter and I cut up a SRI to use with the stock box. I gained .75 average, but the low end response improved alot. I want to wrap it with heat wrap because it gets a lot of heat soak being above the exhaust.
I think the smoothness of a SRI piping can help with things such as throttle response but the heat soak of metal vs plastic has to be considered as well because the results can me marginal like with my Lex.
Filter is key!!! You could have the baddest intake but ya ain't got jack if your using a crappy filter!!!
speedjunkie_g35 is offline   Reply With Quote
Old 05-24-2012, 11:02 AM   #14
Quote:
The new aem filters are actually made by k&n...........
dlo253 is offline   Reply With Quote
Old 05-24-2012, 02:11 PM   #15
butterbeer2fd's Avatar
lol the differences are so minuscule it doesn't matter, if you're going for an intake it's all sound really, you're not gonna have noticeable gains so for me I just went with the SRI cause it's cheaper
butterbeer2fd is offline   Reply With Quote
Old 05-25-2012, 09:14 PM   #16
teg your it's Avatar
neither is better for mpg. if you want BETTER mpg, get a header, new cat and exhaust system. if you want even more, low boost it.
teg your it is offline   Reply With Quote
Old 05-26-2012, 02:55 AM   #17
Quote:
arguable.
Old 07-27-2012, 05:25 AM   #18
Quote:
I'm pretty sure they stopped using K&N filters a few years ago.
vladd is offline   Reply With Quote
Old 07-27-2012, 05:57 AM   #19
Daisy... Daisy...
Dogginator's Avatar
I'm averaging 34 mpg recently (summer) in 50/50 driving with 10 mile trips. I have the OEM air box with a K&N filter and custom tube that replaced the air intake resonator. This tube pulls cool air from the fender like the OEM ITR intake system.
For MPG, it seems that you would want to run warmer intake air, but not to the point of preignition.
Dogginator is offline   Reply With Quote
Old 07-27-2012, 06:41 AM   #20
Local's Avatar
That's some beautiful mileage.
Local is offline   Reply With Quote
Old 07-27-2012, 11:58 AM   #21
My gsr in my 94 civic vx averages 34.5 mpg (2.5" egay cai w/ K&N filter,skunk2 pro im, Hytech rep header, 60 mm exhaust, no tune) and that is with me enjoying every second of driving. I am curious what I would get if I was to baby it the whole tank.
Old 07-27-2012, 12:06 PM   #22
Daisy... Daisy...
Dogginator's Avatar
Try it and find out. I never have enough discipline.
Old 07-27-2012, 12:12 PM   #23
That's my problem since it is my weekend warrior. I may start out easy on it but it is too hard to not enjoy driving
Old 07-27-2012, 10:08 PM   #24
pretty simple stuff; more (denser) air = more fuel, as commanded by the ecm through o2 sensor readings. which equates to more power but lesser fuel mileage.
you want better mileage on your stock ls? try advancing ignition timing 2 or 3 degrees. you'll get a bit more power freed up and actually gain mpg. free of charge
el crapitan is offline   Reply With Quote
Old 07-29-2012, 06:12 PM   #25
i got an intake jus for looks aha
Heng209 is offline   Reply With Quote
MPG with Cold Air Intake Jim Dan Honda Civic (2001 - 2005) 16 04-18-2013 09:20 AM
Stock Airbox Replacement? civics4lyfe Honda Civic / Del Sol (1992 - 2000) 1 04-05-2012 05:32 AM
1997 civic hx short ram intake help rawrjaay Honda Civic / Del Sol (1992 - 2000) 6 09-09-2011 08:40 PM
'97 Civic EX Short Ram intake to stock. No fuel economy improvement. rwingslsoccerc Honda Civic / Del Sol (1992 - 2000) 5 07-31-2011 08:42 PM
Questions about intakes suds1485 Honda Civic (2001 - 2005) 2 04-04-2011 08:44 PM
Tags
1996, acura, air, ep3, filter, intake, integra, milage, mpg, mpgs, ram, rsx, short, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
