Shifter won't go into gear when the engine is on after installing new clutch
Hi,
Last week, I went to the race track. As I shifted into 3rd, it was very hard to shift into and after that my car wouldn't move. I had it towed home and ripped the transmission out to discover a blown clutch disc. I ordered a ACT 6 puck clutch disc and my friend gave me his Stage 2 Exedy pressure plate with 2,000 miles on it. I'm currently running a Toda flywheel. Is there anything wrong with my setup?
Well I assembled everything today and thought I did everything correctly. Fired it up and I couldn't get it into any gear. The clutch pedal had a lot of play and was stiff, but wouldn't disengage. With the engine off, I could go into gear. Started the car in gear and it would move. I noticed that when I tried to put it in gear with the engine on, the car would move slowly, but the gear wouldn't engage. I checked out the slave cylinder and it moves when I press in the clutch.
I moved the shift fork back and forth and its super loose. I'm guessing the spring holding the throwout bearing is damaged, or the bearing is damaged? It worked fine when I checked it out before I put the transmission back on. Could it be anything else? I'm tired of taking the transmission on and off. I would appreciate any help pinpointing the problem. Thanks.
Re: Shifter won't go into gear when the engine is on after installing new clutch
Did you bleed the system after the swap? Dumb Question. but is the trans lined up?
Yes I did bleed the system. The trans is lined up correctly.
idk but its possible a bad tranny or did u replace the bearing in the motor where your put the flywheel?
Aaron Whitehead
12-14-2018 08:29 PM
Nisif
10-14-2012 11:26 PM
mr_munro
05-12-2011 11:48 PM
ouprimetime
07-08-2004 09:57 PM
