Shaking during WOT???
Ive got a 94 LS, and for the past few weeks now, whenever I accelerate, the entire car starts shaking back and forth. At first I thought It was probably my drivers side axle (since the boots been split for a few months), but I just want some other ideas on what the hell it may be. It doesnt seem to do it it 1st, but any other gear, I can be at 1500-3500rpm, step on it, and about 4000-5000rpm, its like an earthquake inside my car. I cant bring it past 5200 without getting scared the whole damn thing is gonna shake itself right off the road. Please help!Any suggestions are greatly appreciated! Thanks
Re: Shaking during WOT??? (MrMayhem)
Get it aligned. Mine did that after i hit a pothole and it threw off the tow on the alignment. Also, it could be a bent wheel, unbalanced tires..
Re: Shaking during WOT??? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">It's probably the inboard joint on the axle, driver's side more than likely.</TD></TR></TABLE>
If the shaking happens at a certain speed range, only when the throttle is open, regardless of gear or RPM, it's the inboard axle joints. If it happens at a certain RPM range it's something engine related.
If it's related to alignment or wheel/tire balance/roundness, you would feel it at all speeds.
Re: Shaking during WOT??? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">
If it's related to alignment or wheel/tire balance/roundness, you would feel it at all speeds.</TD></TR></TABLE>
not exactly.. mines off a little bit, and i dont feel it until im goin 60 or higher.. anything below that feels like normal driving
You said you axle boot is ripped? And its been that way for a few months? Get those things changed out before before the joints pop out or break, then your *** gonna be stuck.
xanonymousx
10-24-2007 03:14 PM
MugenHonda
10-01-2005 07:26 PM
