Help please: Radiator fan not turning on automatically (causing overheat)
Old 02-12-2007, 06:48 PM
dck20a's Avatar
Default Help please: Radiator fan not turning on automatically (causing overheat)
I have searched and found same answers (folloed most of it).
I am trying to help my friend fixing his overheating car (00 ls integra). Here are my output so far:
-Radiator, Thermo unit, coolant switch are replaced, unfortunately problem still exists.
-I also checked the fuses and all are in good shape and not blown.
-The fan works when A/C-Heater turned on.
What else do I need to check? Could it be the fan relay (fan works but not when it reaches below half of the gauge temp) ? Or might be bad themostat?
PLease help, thanks in advance.
Old 02-13-2007, 07:27 PM
roger93si's Avatar
Default Re: Help please: Radiator fan not turning on automatically (dck20a)
man the only thing i can think of right is makin your fan direct. find the plug right next to the thernostat housing, that should be your fan swith plug. slice them and twist them together and some tape and your done, as soon as you turn your key to on position you should hear your fan come on automatically. problem solved in my case!
joelro28
02-22-2014 12:43 PM
EG2ENVY
16
03-02-2009 12:41 AM
dudeomega2000
01-06-2008 09:51 PM
hondaaccord94
01-05-2007 11:53 AM
EG9_KID
01-28-2005 04:31 PM
Quick Reply: Help please: Radiator fan not turning on automatically (causing overheat)
