screeching noise from the front brake rotor?
Old 02-05-2011, 06:33 AM
ef8-dc2619's Avatar
Default screeching noise from the front brake rotor?
I sometimes get this screeching noise coming from the front brakes. As soon as i start putting pressure in the brake pedal it stops, but when i let off there it is again. It goes away after a couple of minutes. I hav never done brakes on this car and its at 120k. is it just like a wear sensor?
Old 02-05-2011, 06:36 AM
BlueIntegraBoy's Avatar
Default Re: screeching noise from the front brake rotor?
There is a wear indicator tab on the brake pads. Basically it's a metal tab that makes contact with the rotor and will cause a screeching sound.
Old 02-05-2011, 06:40 AM
ef8-dc2619's Avatar
ok, so i just need pads? it dosent pulsate when i brake. whould that metal contact damage the rotor?
Old 02-05-2011, 08:24 AM
Just change the pads. The metal contact could dig grooves. I would get the rotor resurfaced or replaced anyways.
Old 02-05-2011, 08:26 AM
MD426's Avatar
Pull the tires off and feel the rotor or even just look at it, if there are any deep grooves you need to replace them. Unless if they are nice/expensive rotors its usually better to just buy new ones. If you catch it early there will be minimal damage and you will only need pads.
Old 02-05-2011, 05:21 PM
Global Moderator
Jimmy's Avatar
Visually look and see if the pads are worn out.. it's not hard
DUKE LADUKE
04-08-2010 07:50 AM
minime92
04-20-2007 11:14 AM
lo0nY
11
02-20-2005 10:57 PM
93egSIboi
02-01-2005 04:51 PM
PatrickGSR94
04-13-2002 09:42 PM
Quick Reply: screeching noise from the front brake rotor?
