is it safe to drive?
i have a 90 computer in my 91 integra. In a previous post i made, i stated that the check engine light is on because of ecu code 13: atmospheric pressure sensor.
Another member replied and told me that the 90 PA is external, and the 91 is internal
I just need to know if it is safe to drive around without harming anything! Please help!
Re: is it safe to drive? (91ntegra)
You should be fine the sensor mesures the outside air to give a correct air fuel mixture. Higher altitude less air lower more air. The car will just go into a fail safe mode and you should be able to drive it. Worse possibility is you will be running rich and get bad gas milage other then that your fine.
