s2k antena
Re: s2k antena (gumbybum)
is there any other way to do the conversion than this way because i cant find any #10 5mm couplers or studs. everybody just says good luck finding metric around here.....WTF... can anyone help me out or am i going to have to tap some couplers and chase a stud my self
i really dont want to have to result to this
Re: s2k antena (xteg01)
Everyone who says that must not have done the conversion. I had no problem finding everything I needed at home depot. And forget all about the pcp tubing at the whatever angle, totaly useless, all you need are the copling and like 3washes and 3 nuts if I remember correctly...
Re: s2k antena (Pollux)
man the homedepot, truevalue, blue collar supply and osh all didnt have what i needed.....did you just use the standard size and rape it on or what because they didnt have the metric size only standard....am i missing something here or is elk grove just anti metric?
Re: s2k antena (00gsrBrynn)
yes it will work on a four dour and the reception is pretty good from what i hear as long as you use the radio coax thing like in the link provided..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gumbybum »</TD></TR><TR><TD CLASS="quote">is there any other way to do the conversion than this way because i cant find any #10 5mm couplers or studs. everybody just says good luck finding metric around here.....WTF... can anyone help me out or am i going to have to tap some couplers and chase a stud my self
i really dont want to have to result to this </TD></TR></TABLE>
There is no such thing as #10 5mm, #10 is a standard size and 5mm of course is metric. You have to buy a #10 coupler nut and then tap out half of it to the 5mm thread used on the S2K antenna. The other half of the coupler (still #10 thread) is used by the #10 bolt or threaded rod.
Instead of gluing a piece of angled PVC to a fender washer, I glued the angled PVC into a PVC endcap, and drilled a hole in the middle of the endcap. Works much better IMHO and it also reduces the amount of metal in the setup that might reduce reception.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00gsrBrynn »</TD></TR><TR><TD CLASS="quote">i want one but do you think the reception is the same?</TD></TR></TABLE>
It should be about the same, but if you want the reception to be better get a radio ampplifier from like Radio Shack.
Nate047
11
08-16-2005 01:41 PM
