running rich effect fuel economy?
1 Post
Re: running rich effect fuel economy? (p1ccoloz)
Yes...running rich means excess fuel in combustion chamber=lower MPG. Black smoke from the exhaust is a sign of running rich or but most accurate way to tell is to to use a wideband 02 sensor and get readout of A:F ratios. HTH
Re: running rich effect fuel economy? (Eva01)
how do you fix this without replacing the FPR? also would poor gas mileage be a result of getting valves adjusted? thanks
[Modified by p1ccoloz, 7:03 PM 3/27/2003]
1 Post
Poor gas mileage might be fixed by adjusting the valve, but only if bad valve clearance was the problem to start with.
If you are running rich, should be able to tell looking at your exhaust tip. It should have black stuff around it, or you can smell gas from the tip of the exhaust. Another way to tell is to remove your spark plugs, they will have black film around the tip.
Uf tiy are running rick, you should replace your 02 sensor, air filter, fuel filter, and make sure your timing is correct.
Re: running rich effect fuel economy? (mickey513)
i am running my exhaust tip is filthy. i recently replaced o2 sensor, and fuel filter, and timing is correct was well. could there be anything else?
I wouldn't just rely on your exhaust tip. The entire back end of the car is going to be dirty due to the vaccum formed by moving through the air.
I assume you aren't getting any check engine lights (CEL) ?
Take a look at your spark plugs, see what they look like. Whens the last time you replaced them?
Do you see any black smoke when you go WOT?
Re: running rich effect fuel economy? (MachAF)
not trying to thread hijack but i have the really dirty back bumper and black smoke occasionally. and my a/f gauge is always on rich... havent replaced the fuel filter yet? what else could i replace.. maybe some of my mods conntribute to this.. and also my timing is slightly off still
thanks
chris
thanks
chris
i like the idea of changing the seals on those injectors and the o2 sensor. But how much do they cost though? I have a 94 gsr and RC310cc injectors. will the stock fit the rc's? oh and how much is the o2 sensor? thanks
Re: running rich effect fuel economy? (Typiko512)
i do get a white puff or so says my gf. just wanna get some more mpg even though i get almost 200 now from my previous 120 i still need more! I need help!
