Resurface Flywheel required??
I'm replacing my stock clutch and tranny and I heard I should resurface my flywheel when I change the clutch disc & pressure plate....is this really required? Can I get away w/o touching the flywheel at all?
Also, where is the "pilot bearing"--my helm's didn't mention it on a clutch replacement...only the release bearing. Could the pilot bearing be the flywheel bearing? Thanks for any help.
Re: Resurface Flywheel required?? (3rdGteg)
Run your fingers across the surface of the flywheel to check for any deep scoring or gashes. If the gashes are deep enough to catch a fingernail, then resurfacing is recommended.
Otherwise, just clean up the mating surface of the flwheel with brake parts cleaner to get off any oily finger prints and lightly sand with a high grit sandpaper to take off any glaze and to freshen up the surface for proper break-in of the new clutch friction surface.
The pilot bearing is also known as flyhweel bearing.
Re: Resurface Flywheel required?? (IN VTEC)
What's the going rate for resurfacing flywheels?
And also, is there a special method to properly break in a new clutch?
Thanks for the replies.
[Modified by 3rdGteg, 8:14 AM 7/19/2002]
General rule is to just go easy on it.
No excessive slipping.
No riding the clutch.
No using the clutch to hold the car on a hill.
No dumping the clutch at high rpm's.
Avoid jerky engagements as much as possible and it should be just fine. The smoother the better.
raidacaipo
05-09-2009 07:21 PM
Jet Black
13
08-12-2003 06:09 PM
