da cuts out
Old 02-06-2011, 04:49 PM
b17itr's Avatar
Default da cuts out
ok peeps been awhile since i've been here- i started using my 92 da again but got problems. i had it sitting for a couple years and retuned recently. the problem is driving home in stop and go traffic car cutsoff. it will start again but cutout after 15-20 mins. let it sit and cool down it will restart and die out again after 15-20 mins. check fuel injectors all are firing. replaced fuel filter -check it clean no deposits. check power and ground to fuel pump=ok i did notice that my tach goes crazy while driving and when the car dies out fuel pressure is low around 20 - not sure if my ecu or my distributor is the culprit.any ideas ...btw, no codes
Old 02-06-2011, 05:18 PM
Bowl_of_Rice's Avatar
Default Re: da cuts out
check your main relay im pretty sure thats a common problem with DA integras
Old 02-06-2011, 08:25 PM
el vtec monster's Avatar
did you change your fuel filter or fuel pump?
Old 02-07-2011, 05:18 PM
b17itr's Avatar
i changed both filter and fuel pump
b17itr's Avatar
i'll check the main relay
Old 02-07-2011, 07:35 PM
ek4ther's Avatar
My car was like that. It was the dizzy for me.
Old 02-07-2011, 07:45 PM
mrchevez's Avatar
Same thing for my integra. It was the dizzy
B-Rex
01-22-2009 06:19 PM
dsturch1
10-15-2007 10:47 AM
Slyfox_racer
09-16-2007 01:04 PM
Slyfox_racer
09-13-2007 03:17 PM
94b18c
08-30-2004 10:21 AM
Quick Reply: da cuts out
