replaced tranny fluid on gsr and tightened and leaks tranny fluid help!!
sup honda tech i recently did a tranny fluid drain on my 96 GSR and tightened the drain bolt and is leaking any suggestions?
Re: replaced tranny fluid on gsr and tightened and leaks tranny fluid help!!
nope never installed any crush washer that might be the problem
The drain and fill plug washers should be replaced everytime they are removed, & they are both slightly different in size from each other.
Any Honda/Acura dealer can supply these
Technical Hero
Honda/Acura or you probably can get one at any autoparts store
#20, 25 cents at Acura
94109-14000 WASHER, DRAIN PLUG (14MM) 002 1996 INTEGRA
