Replaced clutch/flywheel, roaring noise
So, I'm really worried. I just replaced my clutch and flywheel yesterday. I went with an Exedy OEM disc, and 8lb Fidanza flywheel. I've only put about 35 miles on it as of today. I noticed when I was heading home from work just now, that there's a roaring noise that sounds like it's coming from the transmission. I used Honda MTF that I picked up from the dealer, and I've read some things about people not trusting their new formula?
When I got into my apartment complex, I put it in neutral and let the clutch out, the roaring was definitely speed dependent. Also, there was a vibration-type sound that was RPM dependent only when the clutch was out. It occurs when sitting still and revving, and when actually driving in gear. The second noise was present before the clutch, and it's still there after the replacement.
I tried searching, but couldn't really find any answers pertaining to my problems. Advice?
Re: Replaced clutch/flywheel, roaring noise
1. for vibration noise go back and check those tranny mounts if they are lose they can cause this vibration you are hearing.
Did you check the pressure plate and bearing ?they mite need to be replaced..
2.check pressure plate and also "Release /throw out" bearing as if it is toast it would be noisy and that would rotate with engine speed?
im no mechanic just trying to help
im having somewhat of the same problem.... not a brand new clutch and flywheel, but the noises are present and sound the same to me. i think my throw out bearing/ my input shaft is bad or is starting to go out. i do need to change transmission fluid though.
I replaced everything with the kit. Clutch disc, pressure plate, flywheel bearing, and throwout bearing. And of course, the flywheel itself.
I torqued the flywheel bolts to 79 ft/lbs using quarter torque steps. First to 20, then 40, then 60, then stopped at 79. Also used thread locker on the bolts.
Also thinking about the roaring noise. It's not spectacularly loud, I really had to listen for it on the road. The sound of just engine noise makes it hard to hear.
I also forgot to mention I got two quick whiffs of MTF as I was driving yesterday, and last night. I checked underneath, and didn't see any leaks anywhere..
Yeah, that's why I'm stumped. I have read something, this morning, about someone saying the input shaft bearing inside the transmission could be the culprit for the RPM-based noise.
My main concern is for the Speed-based *roar*. It's got me clueless.
not exactly. it can also make the roaring noise, sometimes sounding like a bad wheel bearing. (my bad isb would roar at speed, did not make any noise at idle with the clutch pedal out)
Can that be replaced?
Yeah, it was there before. It sounds exactly the same as it did. If I would've known what it was, I would've taken the trans apart while it was still in the shop. Poop..
I can't catch a break. Today when I was pulling into the office, the CEL came on. Now I have to figure out what's causing that.
Oh, and the roaring seems to be getting worse by the day. I may have to replace the bearing sooner than I wanted to..
jbpnoman
02-25-2012 03:45 PM
luder22
10-21-2004 12:59 PM
