Replace valve cover gasket?
I'm thinking about repainting my valve cover because the paint is peeling off. Would I need to replace the valve cover gasket if I take the valve cover off just to paint it?
Re: Replace valve cover gasket? (g3teg97)
yeah you would have to if you want to maintain a good reliable seal... you could always try it, but you cant be sure, best just to replace it, while your at it do a valve adjustment
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g3teg97 »</TD></TR><TR><TD CLASS="quote">Don't you have to replace the spark plug seals as well?</TD></TR></TABLE>
those also come in the valve cover gasket set... You can either order the kit from honda or prostreetonline
OR any of your local parts stores. Felpro Rubber is fine. I beileve I paid 22 or 29 from advance auto. I cant remember the total
I just did mine this past weekend actually. I put 8 little dabs of rtv where the gasket will hump over the cams for added security.
Aodhan
09-28-2007 10:15 AM
