removing double stick tape
help. Whats the best way to remove d. Stick tape with out damaging the bumper paint? And where can i find it? The tape has been on for a while
Re: removing double stick tape (OOOtony)
you can try a hair dryer to loosen it up, then apply goof off with a rag. repeat. try that. buy the stuff at walmart or target or wherever.
Re: (rufridn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rufridn »</TD></TR><TR><TD CLASS="quote">3M adhesive remover</TD></TR></TABLE>
Where can i get that
Re: (OOOtony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OOOtony »</TD></TR><TR><TD CLASS="quote">
Where can i get that</TD></TR></TABLE>
x2
x2
Re: (OOOtony)
Goof Off works just fine, but you can probably find the 3M stuff at a NAPA or other auto parts store. It would be a good idea to not let the goof off sit on the paint too long, by wiping it with a towel with water afterwards.
Re: (OOOtony)
i got mine from Walmart. it's a spray can
Yeah, or you can try to saw it off with floss/ fishing line. Then go back with the spray to get off the residue. Might take a while if you just spray it and wait. Basically the same process you would use to debadge.
Good luck!
Good luck!
Re: (bakertime)
if the goo gone doesn't work for some reason, you can take some laquer thinner on a cloth and clean it with that. WARNING: the thinner can take off your paint if used too much.
Re: (GoCarInteg)
thx everyone got it off. Everything came off. Then i tried to take of the silicone took some paint off but it was on there for years.
Re: (OOOtony)
if you want to take ANYTHING off your paint, you can can get an "eraser" from a paint/body shop. it's an attachment for a drill but that thing took off everything off my integra, including the adhesive from door guards and stickers that were probably as old as the car. =P
Re: (OOOtony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OOOtony »</TD></TR><TR><TD CLASS="quote">thx everyone got it off. Everything came off. Then i tried to take of the silicone took some paint off but it was on there for years. </TD></TR></TABLE>
so, what did you use to remove it?
Re: (HONDRETTI)
that 3m removing thing it takes a while.. it takes off the tape then the sticky stuff are still there and you spray more and rub it off with a rag and it comes off clean
[Eg.6]LiLbOy916
10-28-2006 09:23 AM
r2d97
42
03-11-2006 01:34 PM
