removing the dash, do i have to remove the climate control?
I cant seem to get the climate controls out, it seems like there are some screws or bolts behind it. How do i remove the climate controls? is it nessessary for removing the dash?
Re: removing the dash, do i have to remove the climate control? (Sinner)
i'm pretty sure you have to remove the climate control first. behind the hazard and defrost buttons are two screws. there is a better explanation on team-integra.net, just search its out there.
which part of the climate control are you talking about? yes it all has to come out. dont forget the little ***** that you use to slide the temp and how hard its blowing off too. and disconnect all harneses before pulling.
Pop out the hazards/defrost button and disconnect the harness. There's a 10mm bolt / or screw i forgot on each side behind those buttons. On the passenger foot area top left corner, there should be a black wire, unclip that and pull off the climate control.
Actually here's a link with pictures
http://www.team-integra.net/se...D=586
preludepower
10-14-2005 09:17 PM
ner0x
06-23-2005 07:17 PM
Zoso1977
11-06-2004 10:57 PM
Mr Boston
20
10-09-2003 05:33 PM
