Removing Clutch and flywheel
I have a b18b. I have taken off the tranny, and now I need to remove the flywheel and clutch. I tried taking the star shaped bolts off, but the 11 mm socket started slipping around. How do I take this stuff off?
Re: Removing Clutch and flywheel (civcexcoupeblack)
you using 12pt socket?
if memory serves me its 10mm not 11
your probably using 6point socket...what you need is a 12 point socket
Re: Removing Clutch and flywheel (shamoo)
Yes, he got it right...make sure you use a 12pt socket. Don't strip those suckers
snatch
16
08-11-2004 08:16 PM
integraautox
01-23-2003 01:14 PM
