will a 96 integra automatic engine harness work in a manual 96 integra?
Old 09-21-2009, 03:04 PM
1nsoman1ac's Avatar
Default will a 96 integra automatic engine harness work in a manual 96 integra?
just like title says...would it work? or will i have to cut something?
Old 09-21-2009, 03:14 PM
1nsoman1ac's Avatar
Default Re: will a 96 integra automatic engine harness work in a manual 96 integra?
bump
Old 09-21-2009, 03:19 PM
DC206R's Avatar
yeah, jsut a couple plugs for the auto tranny taht you wont need to plug in.
Old 09-21-2009, 03:28 PM
seanbev24's Avatar
x2
Old 09-21-2009, 03:32 PM
1nsoman1ac's Avatar
is there any way to convert it? and i have a harness that ive been sleeving and shrink wrapping...but i guess it has a ckf plug and a second 02 sensor plug....so it has 4 plugs that plug into the firewall plugs instead of the three that the firewall accepts. i have a 93 civic with a 96 b18b swap and its wired for vtec...and i want to wire it for just regular b18b and i havent found any harness expet these two. any sugestions would be appreciated
Old 09-21-2009, 03:43 PM
seanbev24's Avatar
find the plugs you don't need, open up the plastic and sleeving on the harness, and remove the unnecessary wires.
Old 09-21-2009, 03:55 PM
1nsoman1ac's Avatar
including the pins?
1nsoman1ac's Avatar
will that throw any codes?
Old 09-21-2009, 04:20 PM
seanbev24's Avatar
If you remove only the plugs/wiring from circuits that aren't needed with your ecu, like the auto tranny stuff, you won't have any codes.
I don't know if the tranny wiring has it's own plug for the body harness or not. If those unneeded wires go into a larger plug that has other wiring, then sure you might as well de-pin them.
hondacurious
11-12-2013 01:14 AM
speedfreek128
02-24-2010 10:23 PM
1nsoman1ac
10
09-22-2009 01:08 PM
nello a.
12-24-2008 12:20 AM
Quick Reply: will a 96 integra automatic engine harness work in a manual 96 integra?
