Removed Power-Steering..odd noise
Well I just got done removing my power steering system and putting in a Dropspeed like setup. Looped, with a T-Fitting to a breather.
The car is still in the air, and I was instructed to just let the fluid drain from the fittings on the rack, and not to turn the wheel whatsoever. I completed the install, and now, while the car is still in the air, im getting kind of a "sloshing" and airy noise when the wheel is turned.
Anyone have any insight?
Re: Removed Power-Steering..odd noise (a1320addict)
it could be that you got air in the lines.......when you put hte fluid back in....did you fill the resv up first...turn the wheel to the left and fill as you were turning the wheel and making sure the fluid in the resv doesnt go below the ( i guess ) the connection were the hose meets the resv tank...that where is sucks in the air....sorry kinda hard to explain without visaul aid
CheezeFrog
11-18-2019 11:11 PM
swizz977
10-11-2012 10:29 PM
Inextricabledrvr
03-18-2009 07:56 PM
