red fluid leaking - Honda-Tech
red fluid leaking
Old 04-05-2008, 06:21 PM   #1
TrueJimmy26's Avatar
Default red fluid leaking
last night i ran over a brick in the middle of the road while driving home. My car would not drive when I rev at the traffic light. I saw red fluid leaking near my passager side. I had to call my friends to push it to my cousin house. Lucky i was down the street from his house. does anyone think it could be my tranny?btw my tranny is auto. Will i need to buy tranny? im pretty tired of this car also
TrueJimmy26 is offline   Reply With Quote
Old 04-05-2008, 06:36 PM   #2
Dilly's Avatar
Default Re: red fluid leaking (TrueJimmy26)
yeah, red fluid is tranny fluid.
try jacking up the car and check underneath to see exactly where the brick hit your tranny.
Dilly is offline   Reply With Quote
Old 04-05-2008, 06:53 PM   #3
all-mtr-teg's Avatar
Sounds like you cracked your case.
all-mtr-teg is offline   Reply With Quote
Old 04-05-2008, 07:14 PM   #4
Blahblah718293's Avatar
Default Re: red fluid leaking (all-mtr-teg)
yep, ATF is red, if your tired of the car you can just sell it, or you may get more money if you fix it, it could be as simple as the under cover... jack it up and take a look.
if its just the cover you may be able to pick up one at a junkyard. if not, you may be able to find an auto tranny pretty cheap (since noone wants them and does a 5 speed swap) and have a shop put it in.
Blahblah718293 is offline   Reply With Quote
tranny dipstick causing leaks? whitehf Honda Civic (2001 - 2005) 5 08-20-2012 12:11 PM
Tranny fluid leakage litoekneeil Transmission & Drivetrain 5 06-08-2010 09:53 AM
Leaking intake manifold gasket deerman2701 Honda Civic / Del Sol (1992 - 2000) 3 11-09-2009 05:30 PM
Cracked Tranny question BubbleBoyB16 Welding / Fabrication 2 07-19-2006 03:51 PM
tranny leak stealthhatch Honda Civic / Del Sol (1992 - 2000) 8 03-19-2004 05:48 PM
Tags
2007, 2010, 98, automobile, car, civic, curb, fluid, honda, house, leak, leaking, liquid, odyssey, ran, red
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
