Rattle at idle
Old 06-28-2001, 10:10 PM
New User
ninjaman's Avatar
Default Rattle at idle
I took my car to a tire shop and when I got it back I hear a light rattle only at idle. I notice it's more pronounced when the A/C is on. It's easier to hear the rattle from inside the car then under the hood, and it sounds like it's coming from underneath - maybe closer to the passenger side.
Any ideas what it could be? I'd like to know soon so I can go back to the tire shop and rage if need be.
Old 06-29-2001, 01:00 PM
New User
ninjaman's Avatar
Default Re: Rattle at idle (ninjaman)
ttt
Old 07-01-2001, 08:17 AM
ALF
ALF's Avatar
Hey, I have the same problem. When idling, it kinda sounds like I have some racing cams....lumpy. Except the "lumps" are rattles. And it only happens when the engine is heated up. When the engine is cold, idle is fine. Anybody have any ideas?!
This sucks...
[Modified by Dozed, 12:18 PM 7/1/2001]
[Modified by Dozed, 12:19 PM 7/1/2001]
Old 07-01-2001, 09:35 AM
New User
LSIntegra94's Avatar
Default Re: Rattle at idle (Dozed)
It's probably the typical heat shield rattle. Annoying, isn't it!?!
Old 07-01-2001, 11:07 AM
ALF
ALF's Avatar
Default Re: Rattle at idle (LSIntegra94)
Definitely not the heat shields. Took 'em all off.
Old 07-01-2001, 11:19 AM
New User
No kidding!?
Old 07-01-2001, 06:12 PM
New User
ninjaman's Avatar
Yeah, I took my heat shield off when I installed my header. If anyone has any ideas, that would be great.
Old 07-01-2001, 09:10 PM
New User
Mr. Choi's Avatar
hey,
my friend also has this problem after i installed his headders.
i also no what causes this rattle at a certian RPM.
first when you or someone else intalled youre headders did they put the gasket from the old exhaust manifold and trasfer it to the new headders??? i pretty sure they didnt, like i did. the gasket im talkin about it located jus before the catalytic converter. if there is no gasket there then the headder and catalytic is hitting eachother and making that sound, nothing really bad, on my friend car, that rattle + leak made his car faster, i dont no why, but thats what he told me. the rattle you are hearing may not be what my friend is hearing, but maybe its the gasket that wasnt placed in the headder when it was installed. hope i was a help.
Old 07-01-2001, 11:25 PM
New User
ninjaman's Avatar
Default Re: Rattle at idle (ChoisVTEC)
I appreciate your help. Unfortunately, I installed the header about six months ago and there was no sound. It just started a couple days ago after I let these fools work on my car. I think I'm going to have to get under it to try to locate the rattle source. I hope nothing's broken
Old 07-02-2001, 12:11 AM
ALF
ALF's Avatar
Hmm...I'd check for loose bolts.
Old 07-02-2001, 08:20 PM
New User
Mr. Choi's Avatar
Hmm...I'd check for loose bolts. [/QUOTE]
Old 07-02-2001, 09:22 PM
New User
crookedletterd's Avatar
ttt
what does that mean??? i see that people just use it to get thier post to the top.... wait a min does it mean "to the top"?? i am a smart one!
EK45VTi
12-11-2007 06:46 PM
Lmgrcivic
04-11-2005 11:13 PM
scn095
04-08-2003 08:41 PM
Blue teg
11-27-2001 01:12 AM
Quick Reply: Rattle at idle
