Radiator Fan Relay and Wiring questions 90-93 - Honda-Tech
Old 05-20-2008, 06:49 AM   #1
steronz's Avatar
Default Radiator Fan Relay and Wiring questions 90-93
When I was cleaning up the engine bay on my DB1, I got a bit confused as to what was what and apparently snipped off the radiator fan relay. And then threw it out. So now I have to wire it up from scratch, which is no biggy, but I'm missing a wire.
OK, I have the ylw/blk & blk/ylw wires that trigger the relay... that's where I made the snip, and everything past that is gone. The only thing left on that harness aside from the headlight/turn signal wiring are 2 plugs that are either for ABS or A/C, or maybe neither... hell, I have no idea what those two plugs are for, but I'm not currently using them. I've checked out the electrical diagram in the manual, and as I understand it, the only thing I'm missing is a power source (white wire) going into the relay (comes out blue and goes to the fan). I only snipped the 2 wires, so I'm not sure where that white wire comes from. I could always go straight to the battery or fuse box, but I'm trying not to add long wires if I don't have to. Is that white wire in one of those two plugs that I'm not using by any chance? Thanks.
Modified by steronz at 3:10 PM 5/20/2008
steronz is offline   Reply With Quote
DIY: Using a Factory Dash Button as a Fuel Pump Cutoff bmxtrev Audio / Security / Video 8 02-07-2015 06:54 PM
DIY S2k button start /w cruise control harness Solscud007 Acura Integra 33 05-31-2013 07:01 AM
fuel pump wont prime scottied15 Honda Civic / Del Sol (1992 - 2000) 6 12-26-2012 03:33 PM
DIY S2K button start w/ cruise control harness Solscud007 Acura Integra Type-R 21 09-04-2007 12:56 AM
obd0 to obd1 distributer wiring, one green wire left wheres it go? CRXCRAZYD16Y8 Honda CRX / EF Civic (1988 - 1991) 15 02-23-2006 12:32 PM
Tags
90, 9093, 91, ac, crx, fan, honda, integra, loction, radiator, relay, straight, switch, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
