radiator fan, denso and mitsuba(toyo), which is which?
Old 08-04-2003, 09:44 PM
tilt's Avatar
Default radiator fan, denso and mitsuba(toyo), which is which?
I need to replace my radiator fan motor for my 94 gsr, but im not sure which brand I have.
There is a 4 fan blade and a 5 fan blade made by denso and the other by mitsuba. Anyone know which one is which? The auto store im buying from doesnt show which one goes to which. tia
Old 08-04-2003, 09:47 PM
PandaBear's Avatar
Default Re: radiator fan, denso and mitsuba(toyo), which is which? (tilt)
I bet you everyone of them will last you at least 7-10 years. Just look and see which one has the best wiring quality and stiffest frame and that usually is the best quality one.
Old 08-04-2003, 10:03 PM
tilt's Avatar
I guess i wasnt very clear... I have a 4 blade fan but the motor is bad. I dont know of any junkyards around here so I have to look at parts from autozone/advanceauto. They sell just the motors for a much cheaper price compared to the whole assembly. unfortunately I dont know which (denso or mitsuba) goes with the 4-fin fan blade assembly.
Old 08-04-2003, 10:08 PM
tuphatt's Avatar
to tell you the truth I think the denso is the one that is most common. Also, my suggestion is to go ahead and pick up both and see which one works and then return the one that doesn't fit. That is what I did.
good luck
Old 08-04-2003, 10:10 PM
tuphatt's Avatar
Default Re: radiator fan, denso and mitsuba(toyo), which is which? (tuphatt)
forgot to mention that you can drive your car without a radiator fan if you don't turn on the A/C it should be okay for a while if you want to bring your fan in.
Old 08-05-2003, 11:43 AM
tilt's Avatar
Thanks. I ended up purchasing both, and gonna return the one that doesnt fit.
sohctodohc
07-11-2013 09:06 AM
yungvl
07-02-2011 03:56 PM
SGT_Manny
11
06-15-2010 04:56 PM
Obama
03-02-2010 05:33 AM
BHNTech
04-29-2006 07:39 PM
Quick Reply: radiator fan, denso and mitsuba(toyo), which is which?
