radiator fan and condenser fan + a/c compressor wont turn off - Honda-Tech
Old 05-08-2008, 03:25 PM   #1
devils_civic's Avatar
Default radiator fan and condenser fan + a/c compressor wont turn off
94 integra rs - stock
radiator fan and condenser fan + a/c compressor will not turn off. they all turn on as soon as you switch on the ignition and will only turn off when you turn the car off.
i disconnected the water temp sensor on the thermostat and they still run. could it be a relay problem?
i just got this car, i suspected that the person before may have messed with the wiring. but i cant find any unusal wiring.
please help!
Modified by devils_civic at 4:01 PM 5/8/2008
devils_civic is offline   Reply With Quote
Old 05-09-2008, 09:37 AM   #2
please help!
Old 05-12-2008, 08:31 PM   #3
Old 05-13-2008, 02:15 PM   #4
pokmijn's Avatar
Default Re: (devils_civic)
yeah he probably ground the plugs of the fan cause i buddy did that to his car and the fan comes on right when he turns the key.
pokmijn is offline   Reply With Quote
98 Civic LX - A/C condenser fan and compressor not engaging eksedan7198 Honda Civic / Del Sol (1992 - 2000) 20 11-21-2013 03:11 PM
91 crx radiator fan turns on a/c compressor zrickety Honda CRX / EF Civic (1988 - 1991) 2 07-28-2011 05:17 PM
97 Honda Civic Ex Condenser fan and A/C compressor not working atxhonda6 Honda Civic / Del Sol (1992 - 2000) 0 08-14-2009 03:03 PM
help wiring, radiator/condenser fan wont turn off devils_civic Acura Integra 5 06-27-2008 07:17 PM
wiring: radiator and condenser fan! HELP! devils_civic Acura Integra 4 05-07-2008 01:02 PM
Tags
94, ac, acura, civic, compressor, condenser, condensor, fan, honda, integra, radiator, shut, turn, turned, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
