ac clutch not engaging..any help!?!?
Old 05-14-2014, 06:20 AM
Toofresh559's Avatar
Default ac clutch not engaging..any help!?!?
96 integra ac clutch not engaging...had replaced belt, compressor and filled up refrigerant...found out there's no ground going to ac clutch relay...I bypass it and grounded the relay and ac started working...what could be the problem? Bad ecu? Short wire some where? Any help before I take it to shop...
Old 05-14-2014, 06:33 AM
oldschoolmaster's Avatar
Default Re: ac clutch not engaging..any help!?!?
prolly a pressure sensor not working but u really need a wiring diagram
Old 05-14-2014, 06:57 AM
I have the diagram my buddy printed it out for me...its something has to do with A17 not getting any ground...any ideas?? Anyone?
Old 05-14-2014, 07:09 AM
turbohatch96y7's Avatar
Post the diagram and I can tell you where to check.
If its a relay not closing then it should be simple. I don't know how the circuit works so I would need to see a diagram
Old 05-14-2014, 08:03 AM
tamboo's Avatar
spooledupracing is your friend:
http://www.spooledupracing.com/downl...dfbd31fb819d41
it would be nice if links to those manuals could be posted in a prominent place
instead of me having to paste it in on a daily basis lol.
Old 05-14-2014, 10:41 PM
Help anyone?
Old 05-15-2014, 04:49 AM
check the ac pressure switch jump the plug and make sure u have enough Freon it will not work unless that switch wants to
Old 05-15-2014, 06:22 AM
kaycee_00's Avatar
No solid check engine lights on right? I had my ac stop working when my tps died and the car thought it was at 100% throttle the whole time.
Old 05-16-2014, 08:03 AM
No check engine light...and where is the ac pressure switch? How do you jump the plug? Video or pics would be awesome!! Keep coming guys any other help? Suggestions?
Old 05-17-2014, 06:01 PM
anyone? can show me pics of where the ac pressure switch is? and show me how to jump the plug?
Old 05-17-2014, 09:39 PM
fcm
Old Fart
fcm's Avatar
It is on the line coming out of the bottom of the condensor, [drivers side] abour half way between the condensor and the filter/dryer, #6, switch is # 17.
Name:  97 Integra GS-R.png
Size:  27.8 KB 94
Old 05-19-2014, 08:56 PM
Ok so I jumped the ac switch and the ac clutch engaged it started spinning but as soon as I plugged it back it stopped spinning...
Old 05-20-2014, 05:29 AM
kaycee_00's Avatar
Sensor might be bad or you over pressurized the system and need to release some freon.
Old 05-20-2014, 06:05 AM
I am SO fancy!
silvertaxasteg's Avatar
You can follow this flow chart.
Old 05-21-2014, 04:46 PM
fcm
Old Fart
fcm's Avatar
How much "freon", [R134a refrigerant] did you put into the system?
You either have a bad pressure switch or you did not put in enough refrigerant, overcharging the system would still let the A/C compressor turn on and the pressure switch would turn it off when head pressure got too high, [454psi is cut-off on the Integra binary pressure switch]
AZCR-V
Honda CR-V & Element
04-23-2018 07:58 AM
J.Waddell
09-10-2015 05:56 PM
Robert04accord
05-29-2014 04:39 PM
tddavis45
11-22-2012 05:15 AM
Quick Reply: ac clutch not engaging..any help!?!?
