problems after basic maint.
i changed the tranny fluid in my brothers 93 the other day. its a 5 speed, the oil that came out was real thick and dark, not sure if it was every changed. so i put in what i use in my car, the pennzoil synchromesh. it drove brand new for about 5 or 6 days, now unless i let it warm up fully, the car will not go into gear or it grinds bad. is there some reason you shouldnt put synchromesh in cable tranny's or something? it doesnt make any sense to me, it shifted brand new for 5 or so days, now you have to be careful where you shift. it will either grind, be notchy as hell, or just wont go into gear. theres 84K on the car. any thoughts?
Re: problems after basic maint. (danteisme)
is there a leak? how much fluid did you put in on the refill? check your clutch fluid, a leaking master or slave cylinder will also give you these same problems.
how many quarts did you use? was the vehicle level or close to it when you were filling the trans back up? check the clutch fluid level yet?
Re: problems after basic maint. (boostednlinefor)
checkin the clutch fluid level tomorrow, but the car was fairly level, i got right around 2.25 qrts into the tranny. maybe a bit more but not much. im assumin this is normal becuase thats roughly what my car takes.
habanerored06si
Honda Civic (2006 - 2015)
06-15-2013 02:12 AM
allmotor.net
05-23-2004 08:53 PM
