Problem with my GSR!!
I was driving my gsr'd hatch to work this morning and everything was fine. Well I went to the gas station filled it up, and when I went to go start it again it started, ran for a split second, and then cut off. It did it like 4 times in a row and then finally stayed on. So I have let it sit 3 times now since then for a little while and try to start it up and it does the same thing over and over. Sometimes when I try to give it gas it just sounds all boggy and then dies, and sometimes it stays on like it should. Could I need new injectors? Fuel rail? Fuel pump? Is it an o2 sensor problem? Anyone ever had this problem before? Any help in the matter would be appreciated. Thanks.
Re: Problem with my GSR!! (B18chatch83)
i have a 93 rs hatch and it does the samething it will do it for a day and then nothing for a couple of weeks but when it happens i just let it sit for like a min and then it starts right up
I dont think its fuel, because if it was bad gas, then it wouldent run period. Try holding the key in the on position for about 30 seconds, let the fuel pump get some gas to the injectors, and build pressure. I think, that if your pump is starting to go, it isnt pumping enough fuel initially, and thats why it starts after a few attempts
Re: Problem with my GSR!! (JDM_EK_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK_Fanatic »</TD></TR><TR><TD CLASS="quote">I dont think its fuel, because if it was bad gas, then it wouldent run period. Try holding the key in the on position for about 30 seconds, let the fuel pump get some gas to the injectors, and build pressure. I think, that if your pump is starting to go, it isnt pumping enough fuel initially, and thats why it starts after a few attempts</TD></TR></TABLE>
thats what i was thinkin...then again it could be ANYTHING!!!!!!!...
Re: Problem with my GSR!! (project_B18C1)
Well thanks for the reply guys, Well my main relay might be going bad? Well if my main relay was going bad would I still here the initial click? My RPM's don't spike, I mean it will go to like 2 when I start it up and then shut off...
Re: Problem with my GSR!! (RIP Indian Larry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry »</TD></TR><TR><TD CLASS="quote">Main relay?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA6righthand »</TD></TR><TR><TD CLASS="quote">main relay</TD></TR></TABLE>
Re: Problem with my GSR!! (ferngsr)
UPDATE!!!
Ok now it won't stay on at all, everytime I start it it dies, unless I start it and keep the key turned to the start position, I can hold it in the start position and drive it that way, but that's it!!! Still the main relay? I have a fuel pump in another civic I am getting rid of that I can change out. I NEED HELP IMMEDIATELY!!!
Nevermind!!! Problem fixed, was not the main relay, bad gas, or fuel problems whatsoever!! All I did was change the ignition wires from one of my civics to the other one and connected them, problem was fixed. I am thinking the way I installed my steering shaft was bad because it looked like it was pinching my ignition wires. Thanks for the inputs though!!!
v6accordcoupejunkie
09-28-2009 05:41 PM
ATS*Mark
10-26-2004 08:16 AM
