Power window problem
Anyone encounter the same problem? my passenger side window just fell slowly one day and i checked to see what happened. My power window motor seems to work fine but im guessing the cable is damaged or loose or something. i can push the window button and you can hear the motor still pulling. Another thing is my driver side power window switch that controls the passenger side window doesn't activate the motor anymore just the passenger side switch does. Anyone have a clue if the cable gone bad or something else?
Re: Power window problem (AzntstyleZ)
that happenned to me the other day..the window fell off of the plastic bracket that holds it on the window regulator..if you take your door panel off you can see whether or not the window is still resting inside the little white brackets...
