Power steering fluid question - Honda-Tech
Old 07-31-2008, 09:19 PM   #1
dgie's Avatar
Default Power steering fluid question
I used a non honda power steering fluid (prestone), will it harm the system? if it is bad how do you get it out?
1998 acura integra LS
dgie is offline   Reply With Quote
Old 07-31-2008, 09:30 PM   #2
BlueIntegraBoy's Avatar
Default Re: Power steering fluid question (dgie)
You can use non-Honda PSF.
BlueIntegraBoy is offline   Reply With Quote
Old 08-01-2008, 10:18 AM   #3
Darth ModerVader
Padawan's Avatar
Unless it was designed for use in Honda, systems, then yes, it will cause harm. You need to drain and flush the fluid, then replace with Honda or Honda-specific fluid.
Padawan is offline   Reply With Quote
Old 08-01-2008, 03:40 PM   #4
dgie's Avatar
Default Re: Power steering fluid question (Padawan)
I bought some at autozone for Honda cars and will flush the system.
Accidentally pour brake fluid to the power steering fluid container tslam Tech / Misc 3 05-22-2012 08:45 AM
Power Steering Fluid curtie94 Honda Accord (1990 - 2002) 3 02-24-2012 01:38 PM
clutch fluid the same as power steering or brake fluid? Flava Honda Civic / Del Sol (1992 - 2000) 4 08-15-2006 10:33 AM
Ran out of power steering fluid and... oryanh Acura Integra Type-R 8 07-07-2002 06:25 PM
Power steering fluid jetli Acura Integra Type-R 4 10-31-2001 01:11 PM
Tags
2001, accord, acura, bad, fluid, flush, honda, hondaacura, integra, mdx, power, prestone, psf, steering, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
