popping thok thok noise upon acceleration and braking
Old 07-10-2006, 09:10 AM
* B A N N E D *
Pnoyej6's Avatar
Default popping thok thok noise upon acceleration and braking
THis noise is annoying me . It feels like something is gonna fall. i have 00 db8 slammed with koni yellows/neuspeed race with front spc ball joint camber kit. Every time i accelerate or brake i hear click click thok thok. What could it be. Its not my cv boot nor axle. Already check for leaks on booth no leaks. Its only making the noise on my front driver wheel side only. Im thinking it could be my spc adjustable ball joint. Should i replace this?? WHat else can it be? balll joint is gone? anyone experience same problem?
I really need to get it fix. I will go ahead and order new spc adjustable ball joint. Btw it started happening couple months ago. It was fine for 2 years until now.I tightened ball joint??
Old 07-10-2006, 09:50 AM
JThrasher79's Avatar
Default Re: popping thok thok noise upon acceleration and braking (pnoytegn707)
is your wheel tight??
Old 07-10-2006, 10:58 AM
* B A N N E D *
Pnoyej6's Avatar
Default Re: popping thok thok noise upon acceleration and braking (JThrasher79)
yes my wheels are tight i tighted the lug nuts myself this weekend
Old 07-10-2006, 11:12 AM
gamemaster000's Avatar
Wheel bearing?
Old 07-10-2006, 11:24 AM
Abusing my rights one day at a time.
Mordeki's Avatar
Default Re: popping thok thok noise upon acceleration and braking (gamemaster000)
wheel bearing or motor mount?
Old 07-10-2006, 11:27 AM
* B A N N E D *
Pnoyej6's Avatar
Default Re: popping thok thok noise upon acceleration and braking (Mordeki)
HOW CAN I TELL wheel bearing or motor mount. Its not motor mount? how about my spc ball joint?
Old 07-10-2006, 11:32 AM
Mordeki's Avatar
possibly....does it happen when you stop suddenly too? If so then it's your motor mount.
Old 07-10-2006, 11:42 AM
* B A N N E D *
Pnoyej6's Avatar
which motor mount ? it happens when i brake little and accelerate only but when im moving no noise?
Old 07-10-2006, 12:08 PM
lol_on_v8s's Avatar
check your cv joint make sure you still have the boot.. or lube.. cause mine is doin the same thing right now..
Old 07-10-2006, 01:20 PM
* B A N N E D *
Pnoyej6's Avatar
Default Re: (lol_on_v8s)
CV JOINT IS STILL THERE NO LEAKS
Old 07-10-2006, 03:33 PM
* B A N N E D *
Pnoyej6's Avatar
Default Re: (pnoytegn707)
its it my motor mount my engine will shake. Come on guys i need help. how can i tell cv boot is broken. I physically check axle and cv joint. It looks fine no rips no grease
Old 07-10-2006, 06:28 PM
mistah4door's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gamemaster000 &raquo;</TD></TR><TR><TD CLASS="quote">Wheel bearing?</TD></TR></TABLE>
if it was your wheel bearing, you would hear a whining sound when your drving. its get louder overtime, but it doesn't seem like this is your problem. did you check all your suspension? strut or sway bar? check make sure its not loose
if your cv boot was broken, you would see a bunch of grease all over the place depending on the size of the hole. also when you turned you would hear a clickin sound
Modified by mistahJDM at 3:45 PM 7/11/2006
ams185
03-15-2014 10:16 AM
jkalex05
11-23-2009 06:52 PM
David12
10
11-15-2009 01:35 PM
dc2doi
10-15-2007 11:23 AM
SilverDc2
01-05-2006 10:25 AM
Quick Reply: popping thok thok noise upon acceleration and braking
