poping sound
Old 01-20-2008, 07:44 PM
mrbigone's Avatar
Default poping sound
1990 gs Integra
b16a swap
ok well I recently swaped my b18 out for the b16a and now I have a problem.
When I start the car it starts fine all the time but a few seconds later it will start making this constant poping sound. The motor has an open header, I can hear that sound from it. A friend of mine said it sounded like if a piston wasn't working properly....so I did a compresion test and they were all fine.
This motor was on my crx before and it was working fine but after this swap it started doing this.
thanks in advance for any help
Old 01-20-2008, 08:01 PM
Reject Papi
jhammond_82's Avatar
Default Re: poping sound (mrbigone)
maybe its because your running open header?
Old 01-20-2008, 08:12 PM
mrbigone's Avatar
Default Re: poping sound (jhammond_82)
when running open header it should make a steady sound....like a deep loud sound. but my motor sounds deep loud with a poping sound.
I had my exhaust hooked up to it and would soud like a gurgle sound kind of...something like how the Subarus sound. I thought maybe something was wrong with the cat or exhaust so that's why now I have it open header.
Old 01-20-2008, 10:21 PM
Dilly's Avatar
what year is the B16 you swapped in?
Old 01-21-2008, 05:54 AM
* B A N N E D *
GRAF-FITI's Avatar
Default Re: poping sound (diLLy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbigone &raquo;</TD></TR><TR><TD CLASS="quote">When I start the car it starts fine all the time but a few seconds later it will start making this constant poping sound. </TD></TR></TABLE>
poping sound?? is the car like humming hallejulah or something?
amen brotha
Old 01-21-2008, 09:48 AM
mrbigone's Avatar
90 Jdm b16a Obd0
Old 01-21-2008, 10:46 AM
aemintgsr's Avatar
Check you ign. timing? should be at 16 degrees for standard
Old 01-21-2008, 11:47 AM
DA_9's Avatar
Default Re: (aemintgsr)
Maybe it is.....running rich and the popping sound u hear is unburned fuel??? Maybe...
Old 01-21-2008, 11:53 AM
IAMLEGEND's Avatar
bump
Old 01-21-2008, 12:01 PM
knuckk's Avatar
when u have open headers and ur driving when u let off the gas so the car can slow down itself its damaging the exhaust valves in the head im guessing air flows back thru the headers back into the head...dont do alot of driving with a open exhuast
Old 01-21-2008, 01:57 PM
mrbigone's Avatar
Default Re: (knuckk)
see but it's not when I let off the gas...It does it when it's in neutral.
It might be running rich like said above I have to check that and the igntion timing as well.
Can the O2 sensor or the Knock sensor be causing this? one of them might be bad or something????
Old 01-21-2008, 02:11 PM
.xcalibur.'s Avatar
Is it a loud backfiring noise? Try hooking up a cat at least and then listen for the noise again.
Old 01-21-2008, 04:51 PM
mrbigone's Avatar
Default Re: (.xcalibur.)
it's something like backfiring but not exactly...when I just put the cat on, it will make the poping sound softer...and when the full exhaust system is on it will make that gurgle sound.
something I noticed earlier was that if I give it a bit more gas (3000 rpm or more) it runs perfect, but when I let it idle it goes back to the poping sound.
Old 01-21-2008, 04:55 PM
red integra lsr's Avatar
Default Re: (mrbigone)
Sounds like a misfire, you runnin stock cams. what ecu
Old 01-22-2008, 07:40 PM
mrbigone's Avatar
Default Re: (red integra lsr)
Problem fixed!!
It was the spark plug wires.
Thanks a lot for all of you guys help!!
BankSea
08-20-2015 07:18 PM
92B20
25
03-11-2010 07:54 PM
BB1LOViN
04-26-2007 08:52 PM
R-Civic
03-14-2007 10:00 AM
Bklyn TSi
07-11-2002 08:07 AM
Quick Reply: poping sound
