Pop, Clank, sound from catalytic converter region - Honda-Tech
Old 10-25-2002, 03:23 PM   #1
RAB
RAB's Avatar
Default Pop, Clank, sound from catalytic converter region
I'm post this for my bro (Dr. RAB01GSR) he's at work.
Cliffnotes:
Just recently it snowed in colorado, so it got cold down to 25 degrees. He has 01 GSR (obviously) He also installed a full Comptech I/H/E on his car about 3 weeks ago.
Now last night he heard a clank sound that you normally hear after you turn off your car, usually its somewhat quite and comes from exhaust components. However, last we both heard what sounded like that clanking sound except it was loud, about 10x louder than usually. And he just called me from his work and said he heard the "clank" while he was driving.
Any thoughts.
My silly guess
has to do something with the spring loaded bolts.
RAB is offline   Reply With Quote
Old 10-25-2002, 07:44 PM   #2
Mr.Rab's Avatar
Default Re: Pop, Clank, sound from catalytic converter region (RY8127)
ttt, Or did we answer our own question.
Mr.Rab is offline   Reply With Quote
Old 10-25-2002, 07:47 PM   #3
Default Re: Pop, Clank, sound from catalytic converter region (Dr. RAB01GSR)
Are you guys certain that it is coming from the CAT area? Definitely check the bolts of course. Other than that, check to see how much clearance does the exhaust have against the heat shield, and check the rubber hangers. I'm no expert, but these are things I would check first.
Good luck,
Oz
The_Oz is offline   Reply With Quote
Old 10-25-2002, 07:55 PM   #4
Mr.Rab's Avatar
Default Re: Pop, Clank, sound from catalytic converter region (The_Oz)
We haven't check all that ****, because it's cold as ****. But tomorrow I'm going to go take a drive get everything hot and tighten the bolts all around.
Metallic rattle / clank clank coming from left front wheel on sharp turns... The Hire Tech / Misc 3 12-09-2011 02:22 AM
Weird clanking sound from front end of car upon acceleration...axle bad? erikiksaz1 Acura Integra Type-R 7 08-01-2010 08:57 PM
Newbie with a bit of a problem notwerk Acura Integra 10 10-03-2006 09:49 PM
Automatic Transmission Clanking??? civic91 Acura Integra 5 07-07-2006 12:31 PM
clank sound from clutch 2000gsrsedan Acura Integra 1 08-26-2003 01:05 PM
Tags
car, catalyic, catalytic, catylitic, clank, clanking, converter, convertor, honda, noise, pop, popping, pops, sound, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
